Ir para o conteúdo principal
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
trackpad button not clicking, too sensitive
It has slowly become worse - the button below the trackpad won't click down depending on what the computer is on (my lap or desk. oddly it still works when the computer is on my coffee table). The corners will click, but not the center. It does read clicking though - it has become too sensitive, to the point that sometimes scrolling or more often have my wrists or palms touch the edge of the computer (but not the button) results in a perceived click. It's gotten annoying because it means sometimes while i'm typing it will have "clicked" without me realizing it, erasing text or something of the like. I'm not sure if the plastic itself has warped or if that could somehow cause sensitivity to clicking on other parts of the computer.
I am not sure if it is related, but part of the casing of the battery won't lay flat anymore, and so the battery bulges a bit from its section. I say this because part of the battery is below the trackpad section, and I'm wondering if this could contribute to the click sensitivity (bringing the sensor closer to the plastic casing or something).
What's the problem here? Is there something I could replace to make this go away?
  • under trackpad preferences, there does not appear to be a setting for the sensitivity of the button itself, just the scrolling speed and double-click speed. clicking for the trackpad is off.
  • my current trackpad settings are: tracking speed (5/10), double-click speed (5/10), scrolling speed (5/11), checked boxes: use two fingers to scroll, allow horizontal scrolling, zoom while holding ^control, secondary clicks, ignore accidental input, and ignore when mouse is present.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
3 respostas
Pergunta mais útil
The bulging battery is putting pressure on the underside of the trackpad button. If you remove the battery you'll find that it's nice and clicky again, so a new battery would be the best way to fix this.
Esta resposta foi útil?
Pontuação 3
1 comentário:
Agreed. Hope the bulging battery hasn't done permanent damage to the topcase. To check - operate without battery and see if this remedies the issue. +
por
This sounds like you have some trackpad settings set wrong.
Click the Apple logo in the menu bar, then select "System Preferences..." Click the Mouse/Keyboard icon, and select the trackpad tab from the top. Check if the setting there are what you want them to be.
It sounds like you want to turn off "Clicking" which lets you use the trackpad as a button by tapping lightly with a finger.
Pontuação 0
http://ibloggedthis.com/2006/06/29/an-or...
Try this.
Pontuação 0
Adicionar a sua resposta
faunablues será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 4,464
