Engine code for Honda civic
What dose engine code d0135 mean for 1999 Honda Civic
Esta é uma boa pergunta?
Obtenha acesso rápido a guias, peças e respostas para seus dispositivos
Joeb, never seen a D0135, only a P0135 which means "Oxygen O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 1)" To repair that I would start by replacing the oxygen sensor as well as checking the wiring harness to make sure it is not damaged.
Esta resposta foi útil?
I had quite an issue with my 1998 Honda Civic HX, told me the oxygen sensor was lazy, even for a new sensor. Turned out that the ECM needed more recent firmware, but an update was not possible. Ended up getting a replacement ECM which cured the problem.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 818
