Ir para o conteúdo principal
Informações de reparo e resolução de problemas para tratores cortadores de grama da marca Craftsman.
Engine WIll not crank
Craftsman riding mower engine will not crank. Installed new battery and still will not crank.
Esta é uma boa pergunta?
Pontuação 11
4 comentários
Is the mower turning over at all or is it just a dead mower?
por
turning over backfires thru carb
por
adjusted air gap valves set gap on coil
por
after I changed my blades incorrectly the pgt9000 would not start with the switch. I can jump the solenoid and it will crank and run . I changed the switch and the solenoid , but still have to jump the solenoid. I think there is a relay that blows if the blades aren't on correctly, but I can't find it.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Are you getting any response when you turn the ignition? If not, it may be your starting solenoid or spark plug. Both are sold as replacement maintenance parts at most retailers who carry lawn and garden supplies.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Pamela será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 17
Últimos 30 dias: 48
Ao todo: 2,293
