Engine WIll not crank
Craftsman riding mower engine will not crank. Installed new battery and still will not crank.
Esta é uma boa pergunta?
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 26
Duração total: 1,670
4 comentários
Is the mower turning over at all or is it just a dead mower?
por Nathan Wells
turning over backfires thru carb
por allenperkins364
adjusted air gap valves set gap on coil
por allenperkins364
after I changed my blades incorrectly the pgt9000 would not start with the switch. I can jump the solenoid and it will crank and run . I changed the switch and the solenoid , but still have to jump the solenoid. I think there is a relay that blows if the blades aren't on correctly, but I can't find it.
por meriview@aol.com
