Ir para o conteúdo principal
iFixit uses cookies to enhance site functionality, analyze traffic, and personalize ads. By using our site, you agree to our cookie use and Privacy Policy.
14 Megapixel camera. Has 12x Optical zoom, 48x Digital zoom, OIS, HD video with Stereo microphones and autofocus. Comes in Red or Black. This camera supports the following memory cards: SD/SDHC/SDXC/EyeFi (full support).
My flash does not work
why doesn't my flash work?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Does it not work as in not fire, or not pop up?
If it doesn't pop up, there could be debris preventing it from working correctly. Check for debris and if you find any, clear it out with a soft cloth or toothpick or even a soft bristle toothbrush.
Also, if it isn't popping up correctly, it could be that the spring attached to the flash has either broken or come loose.
If the flash isn't firing then the bulb could be out.
Also, you should be able to go into the settings on the camera to make sure the flash is turned on, or that it is dark enough where you are trying to take a picture for the flash to actually fire.
Check out the troubleshooting guide for more information.
Esta resposta foi útil?
Pontuação 0
Related Parts and Tools
Adicionar a sua resposta
Joe Henry Smith será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Ao todo: 1,190
