Ir para o conteúdo principal
An upgrade of the Nintendo Game Boy Advance, the Advance SP was released, in North America, on March 23 2004 with a square structure and clam-shell design.
20 Perguntas Visualizar todos
My SP wont start! please help
hello guys, i have a problem with my old SP. it doesnt start, the only thing that i does when i switch it os is a blinking orange light and the screen also blink once. i tried it on the charger directly without the battery and it does the same thing. please help
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
The blinking orange light usually means that the battery needs charged. If it is very discharged then plugging it in won't do any good until you leave it plugged in for a while to let it charge a little before you try to start it up.
I would let it charge for a long period of time. If it still won't start up then I would replace the battery.
I hope this helps!
Esta resposta foi útil?
Pontuação 1
If you still are having problems you might want to check the charger. it could be the wires in charger are broken or the battery type thinge in the charger is broken.
Pontuação 0
Adicionar a sua resposta
Kaostandin Mihallari será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 1,377
