Ir para o conteúdo principal
How to fix the seventh generation of Honda's compact car.
How to replace a front bumper?
The front bumper seems to keep dropping down.
How to replace the front bumper for a honda civic 2004 model please?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Pergunta mais útil
Honda Civic, this from the manual:"
Front Bumper Removal/Installation
NOTE:
Have an assistant help you when removing and installing the front bumper.
Take care not to scratch the front bumper and body.
Put on gloves to protect your hands.
Remove the front bumper as shown.
Install the bumper in the reverse order of removal, and note these items:
If equipped, make sure the front fog light connector is plugged in properly, and the headlight washer tube is connected properly.
Make sure the front bumper engages the hooks of the side spacers and upper beams on both sides securely.
Replace any damaged clips.
A before B before C.....you get the idea. Hope this helps good luck.
Esta resposta foi útil?
Pontuação 2
Gear Up For Future Repairs
Adicionar a sua resposta
Honda Civic será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 45
Ao todo: 9,827
