Ir para o conteúdo principal
Repair for speakers, stereos, header units, and CD players for your car or truck.
vauxhall meriva radio code
i need a code for my 2004 meriva
Esta é uma boa pergunta?
Pontuação 13
5 comentários
I get SAFE but then it shows 6 instead of 10 ? H-E-L-P !
por
You can get a vauxhall radio code here: https://radiocodevault.com/vauxhall/
por
I get safe it show 7 instead of 10
por
كود ٢٤ في سيارة فوكسيل ميريفا ٢٠١١
por
!!! Please !!! HELP !!! Need audio code for OPEL MERIVA, serial number is GM020531818417. Send in mail: pitomiandjeo@gmail.com Thank you!
por
Adicionar um comentário
1 resposta
Solução escolhida
gareth, if you do not have a code, you may want to try this site. If you do have a code try this:"
Entering code into stereo:
Turn Off Stereo
Switch On Ignition (No Need To Start Engine)
Press & Hold Preset " AS " and
Switch Radio On - Display Shows
" SAFE " And Then Shows " 10 - - - - "
Press preset " 1 " repeatedly for 1st Digit
Press preset " 2 " repeatedly for 2nd Digit
Press preset " 3 " repeatedly for 3rd Digit
Press preset " 4 " repeatedly for 4th Digit
If the correct code number is now shown
Press & Hold Preset " AS " Until the Unit Beeps
INsP message:-
Ignition Off
Hold Trip Reset In (keep held in)
Press brake pedal (and keep pressed)
Turn on Ignition
Still Hold Trip Reset and brake pedal for approx 10 seconds, the INSP should change.
release brake and trip reset.
switch off ignition
switch on ignition and check. " hope this helps, good luck.
Esta resposta foi útil?
Pontuação 1
3 comentários:
Where is trip reset
por
My radio show safe7 not ten
por
My is Siemens 2005 vdi
por
Adicionar a sua resposta
gareth será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 57
Ao todo: 33,680
