How to remove front bezel from rear panel
Hi together,
is it possible to remove the front bezel from the rear panel and how can I do this?
Thank you in advance.
Best regards Lance
Esta é uma boa pergunta?
Hi together,
Best regards Lance
If it were possible it would likely require that you follow this guide then use a heat gun to melt the glue holding the bezel to the plastic case. Be careful no to melt the case. If that doesn't work it likely isn't possible. There is no iFixit guide for doing it, which tells you something.
Esta resposta foi útil?
Related Parts and Tools
Shop allÚltimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 2,851
