Ir para o conteúdo principal
Unveiled at the 2000 North American International Auto Show on January 10, 2000, the redesigned 2001 Dodge Caravan and 2001 Chrysler Town & Country were released for sale in August 2000.
Engine over heats at idle
the engine overheats at idle, but cools down when the car is moving, what's wrong
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Jason Dixon, there are multiple things that can cause this. First check to make sure that you have enough antifreeze in your vehicle. Then make sure that your belts are tight enough and not sleeping. After that make sure that your fans are coming on, and check your radiator for any obstruction. Clean it by flushing it from the backside with a water hose. Of course there is also a possibility of a stuck thermostat Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 1
3 comentários:
I've dun the cap ! I've dun the thermostat ! I've dun the circulation ! I am only gits hot when in park Or drive idling setting still gets hot this is a 2005 Dodge grand Caravan 3.8 L motor anybody got any ideas
por
Checked your fan? Possibly water pump....
por
Anybody got any ideas
por
Related Parts and Tools
Adicionar a sua resposta
Jason Dixon será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Ao todo: 3,406
