Ir para o conteúdo principal
PC laptop by Dell with a 15.4" display. Succeeded the Inspiron 1520.
Help debugging broken screen
I have a Dell Inspiron 1535 (Dell Inspiron 1525)
The screen recently stopped working (no dim image, just off). The computer powers on (although it's very quiet so I imagine it doesn't get very far through the boot).
I've taken it apart (all but removing the LCD bevel as it's a bit stuck still) and I can't see any loose connections.
How would I go about determining which part/parts are broken (I just want to know if it's feasible to repair and what parts I'd need.
Any help on debugging it?
Thanks
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
2 respostas
Pergunta mais útil
Adam Quaile, the easiest would have been attaching an external monitor. If that works, you will know that your GPU (video card) is okay. If it does not, you will have some serious problems on the motherboard. So, if you still have it assembled, either re-assemble it, or place it together so that you can start it up with an external monitor to see what happens. If the external monitor works, take a look at the display data cable and make sure it is not shaved on or broken. Check the insulation carefully. If the cable looks okay, you may have trouble with either the inverter or the LCD panel. That is a bit tougher to figure out without the properly tools. I'd start with the inverter replacement and work from there. It is cheaper and easier to replace. The inverter is available at places like this and here is a video that shows you how it's done. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 1
5 comentários:
That was actually the very first thing I tried. There is still no picture using an external display, but I know that sometimes there is no picture until the OS is booted (which I don't think it is).
Perhaps it is a motherboard issue then, but again I don't know what to look for here - no loose connections, everything looks ok at face value.
Great video too, by the way. Thanks for your help.
por
Even without an OS you will still see that computer either is doing a POST or at least have a splash screen. You do not see anything at all when you start your computer?
por
That's correct. With or without an external display, there is no video output whatsoever.
All I hear is the fan starting, the CD drive spinning, and then silence. After a short while the fan does come back on, but still nothing.
por
Since you have no video, external or internal, it appears as if you have trouble with your GPU (video card ) on your logic board. You could try a reflow and see if that helps, otherwise you are looking for a new motherboard.
por
that could be true turkey but it could of also been his cpu as I have replaced the one in my Compaq cq50 which was doing the exact samething it had burnt out and my sister just gave I t to me for parts for my inspiron 1525 since I needed an hdd #toughest computer built inspiron 1525 still kicking since 07 I replaced the cpu and everything was fine afterwards
por
If your PC works fine with an external monitor then your screen is defiantly gone and you might need to order a new replacement screen to fix it by yourself.
Pontuação 0
Adicionar a sua resposta
Adam Quaile será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 270
