Ir para o conteúdo principal
This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
20 Perguntas Visualizar todos
DS charging port damage, can this be repaired?
My son pulled the insides out of the charging port . Is this a repair that I can do myself or should this be done in a repair shop?
Esta é uma boa pergunta?
Pontuação 5
2 comentários
may just be cheaper and faster to buy a decent used one.
por
Garry Dunnan, great that you want to fix it yourself. You have experience soldering? Any damage to the board?
por
Adicionar um comentário
1 resposta
Solução escolhida
Garry Dunnan, most certainly can you fix it yourself. Follow this guide step 13 shows you the port. It is soldered on the logic board. Unsolder it from the board and replace it with one of these. Straight forward repair. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 5
Adicionar a sua resposta
Garry Dunnan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 25
Duração total: 19,761
