Ir para o conteúdo principal
Introdução
Ir para o passo 1
The PlayStation 2 is the predecessor of the new PlayStation 3, and was first shown to the public in 1999. Throughtout the years the console was improved in many ways, recently a slim version of the first PS2 was introduced. The PlayStation 2 can stand on its side or lie flat to fit any space. The console was very powerful when it first came out. The "Emotion Engine", the heart of the console can handle millions of polygons per second, and can simulate weather, words, human behavior and emotions, so that games can react to players' actions in a more realistic way. Once it is installed into your home theater, you'll be treated to a reasonably sharp picture and high-quality sound. The PlayStation 2, like every other console, has a composite A/V cord in the box, which you use to connect the console to your TV. For surround-sound audio, there's a built-in optical digital audio jack. Beyond home-theater integration, you'll find two USB plugs and one IEEE 1394 (FireWire and iLink) port on the front, as well as a port on the back for plugging in the Online Adaptor.
O que você precisa
Ferramentas
Exibir mais…
Vídeo de Apresentação
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua PlayStation 2, use o nosso manual de serviço.
  1. Sony PlayStation 2 Teardown, Sony PlayStation 2 Teardown: passo 1, imagem 1 %32 Sony PlayStation 2 Teardown, Sony PlayStation 2 Teardown: passo 1, imagem 2 %32 Sony PlayStation 2 Teardown, Sony PlayStation 2 Teardown: passo 1, imagem 3 %32
    • On the front right side of the console we have the On/Off and the Eject button for the DVD player.
    • On the front left side we can see the two USB ports and the Firewire port. Two memory card slots, and the two controllers inputs.
  2. Sony PlayStation 2 Teardown: passo 2, imagem 1 %32 Sony PlayStation 2 Teardown: passo 2, imagem 2 %32 Sony PlayStation 2 Teardown: passo 2, imagem 3 %32
    • Let's start with the teardown!
    • First of all we need to remove the Network Adaptor, which also gives you the choice to install a HDD.
    • The third picture shows where the hard disk would be placed.
  3. Sony PlayStation 2 Teardown: passo 3, imagem 1 %32 Sony PlayStation 2 Teardown: passo 3, imagem 2 %32 Sony PlayStation 2 Teardown: passo 3, imagem 3 %32
    • This is the network adaptor we just removed, let's take a look at it before we move on to the console..
  4. Sony PlayStation 2 Teardown: passo 4, imagem 1 %32 Sony PlayStation 2 Teardown: passo 4, imagem 2 %32 Sony PlayStation 2 Teardown: passo 4, imagem 3 %32
    • Turn the console upside down and with a flathead screw remove the rubber covers that hide the 8 screws.
    • On the back right of the console we can clearly see the warranty seal... the point of no return!
    • Once the seal and the screws are gone lift the upper part of the console and get ready to uncover the secrets of the PS2.
  5. Sony PlayStation 2 Teardown: passo 5, imagem 1 %32 Sony PlayStation 2 Teardown: passo 5, imagem 2 %32 Sony PlayStation 2 Teardown: passo 5, imagem 3 %32
    • First of all let's remove the power supply by removing the four screws. In the blue box you can see the large fan, which is in front of the power supply to make sure the temperature is kept as low as possible, and to protect the "Emotion Engine".
    • Here's a closer look at the massive power supply.
  6. Sony PlayStation 2 Teardown: passo 6, imagem 1 %32 Sony PlayStation 2 Teardown: passo 6, imagem 2 %32 Sony PlayStation 2 Teardown: passo 6, imagem 3 %32
    • Here is what is left when the power supply is gone.
    • Now we can easily remove the protective case for the optional hdd.
    • Done that we can unlock the optical drive from the metal frame.
  7. Sony PlayStation 2 Teardown: passo 7, imagem 1 %32 Sony PlayStation 2 Teardown: passo 7, imagem 2 %32 Sony PlayStation 2 Teardown: passo 7, imagem 3 %32
    • Next we need to remove the plastic layer that protects the power supply so we can access to the screws beneath it.
    • Once all the screws are gone we can lift the metal frame by using a flathead screw and some leverage to unlock all four sides from the plastic case of the optical drive.
  8. Sony PlayStation 2 Teardown: passo 8, imagem 1 %32 Sony PlayStation 2 Teardown: passo 8, imagem 2 %32 Sony PlayStation 2 Teardown: passo 8, imagem 3 %32
    • Before revealing the heart of our PS2 we need to remove the massive heat sink that prevents the "Emotion Engine" from overheating.
    • A closer view of the beautiful heat sink.
    • One last thing before removing the metal frame is unplugging the fan from the circuit board.
  9. Sony PlayStation 2 Teardown: passo 9, imagem 1 %32 Sony PlayStation 2 Teardown: passo 9, imagem 2 %32 Sony PlayStation 2 Teardown: passo 9, imagem 3 %32
    • Here is the bottom part of the circuit board.
    • Some pictures of the board.
  10. Sony PlayStation 2 Teardown: passo 10, imagem 1 %32 Sony PlayStation 2 Teardown: passo 10, imagem 2 %32 Sony PlayStation 2 Teardown: passo 10, imagem 3 %32
    • More pictures
  11. Sony PlayStation 2 Teardown: passo 11, imagem 1 %32 Sony PlayStation 2 Teardown: passo 11, imagem 2 %32 Sony PlayStation 2 Teardown: passo 11, imagem 3 %32
    • Before flipping the board and see where all the fun takes place we need to unplug a few connectors that transport data form the circuit board to the optical drive.
  12. Sony PlayStation 2 Teardown: passo 12, imagem 1 %32 Sony PlayStation 2 Teardown: passo 12, imagem 2 %32 Sony PlayStation 2 Teardown: passo 12, imagem 3 %32
    • And here it is... the EE "Emotion Engine" Some specifics about the EE: CPU 128 Bit running at 300 MHz
    • RDRAM 32 MB
    • The GS "Graphics Synthesizer" with its clock frequency of 150 MHz, DRAM Bus Bandwidth 48 GB per second, DRAM Bus width 2560 bits and a Maximum Polygon Rate of 75 million polygons per second... pretty impressive
  13. Sony PlayStation 2 Teardown: passo 13, imagem 1 %32 Sony PlayStation 2 Teardown: passo 13, imagem 2 %32 Sony PlayStation 2 Teardown: passo 13, imagem 3 %32
    • A look at one of the two RDRAM of the PS2..
    • ..at the USB and Firewire ports..
    • ...and more pictures.
  14. Sony PlayStation 2 Teardown: passo 14, imagem 1 %32 Sony PlayStation 2 Teardown: passo 14, imagem 2 %32 Sony PlayStation 2 Teardown: passo 14, imagem 3 %32
    • One last thing to take a look at is the optical drive...
  15. Sony PlayStation 2 Teardown: passo 15, imagem 1 %32 Sony PlayStation 2 Teardown: passo 15, imagem 2 %32
    • On the side of the DVD player there's a little battery that helps the PS2 to keep up with date and time even when not plugged in... not bad..
    • There's a look at the bottom side of the optical drive.
  16. Sony PlayStation 2 Teardown: passo 16, imagem 1 %32 Sony PlayStation 2 Teardown: passo 16, imagem 2 %32 Sony PlayStation 2 Teardown: passo 16, imagem 3 %32
    • Unfortunately our teardown is over, it was really fun, hope you enjoyed it too.
matte18
Membro desde: 10/12/09
423 Reputação
Autoria de 2 guias
2 comentários
I found there were some details lacking in this teardown, and as soon as I removed the top half of the case, I realised my PS2 was quite different inside. I did my own teardown with pix. Want it?
kitadran - Responder
Yes please; can you upload the pictures please
Justin - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 18
Últimos 7 dias: 131
Últimos 30 dias: 568
Ao todo: 76,849
