Ir para o conteúdo principal
Introdução
Ir para o passo 1
A brief look at the internals of the Toshiba/Dynabook Satellite Pro R50-EC.
This model is similar to the other R50 models (I have also repaired R50-B laptops), and parts such as the keyboard, individual keys, and ribbon cables are cross-compatible.
This teardown may, therefore, also help with a similar model.
O que você precisa
Ferramentas
  • Spudger
    Spudger
  • Phillips #0 Screwdriver
Exibir mais…
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Satellite Pro R50-EC, use o nosso manual de serviço.
  1. Satellite Pro R50-EC Teardown, Remove Battery and Screws: passo 1, imagem 1 %32
    • Remove the battery
    • Remove every screw on the underside of the laptop chassis
  2. Satellite Pro R50-EC Teardown, Prise open the chassis: passo 2, imagem 1 %32 Satellite Pro R50-EC Teardown, Prise open the chassis: passo 2, imagem 2 %32 Satellite Pro R50-EC Teardown, Prise open the chassis: passo 2, imagem 3 %32
    • Once the screws are removed, using a flat tool, prise open the bottom of the case from the sides, following around the edges of the laptop until the bottom pulls off entirely.
  3. Satellite Pro R50-EC Teardown, Internals Overview: passo 3, imagem 1 %32 Satellite Pro R50-EC Teardown, Internals Overview: passo 3, imagem 2 %32
    • Accessible replaceable parts include:
    • DVD Drive
    • Memory
    • LCD screen
    • SSD
    • WiFi Network card
    • CPU Fan
    • Keyboard
Mars
Membro desde: 10/08/14
262 Reputação
Autoria de 2 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 12
Ao todo: 155
