Meu Problema
Macbook was slow.
Minha Solução
Couldn’t have been easier!
Meu Conselho
The screws are really small and easy to loose. I used a small magnet to keep them in place.
Cancelar
Este produto não está disponível no seu país.
código do item: IF111-027-1
US$14,99
Desconto iFixit Pro aplicado. Nº de Reg:
US$14,99
Peças usadas do estoque A estão em excelente estado
Peças de estoque B possuem leves marcas de uso
Peças de estoque C possuem marcas profundas de uso, mas ainda funcionam plenamente
US$14,99
US$14,99
Fora de estoque
Pronto para Envio
Pronto para Envio
Fora de estoque
Enviaremos uma mensagem quando o produto estiver disponível em estoque.
Fora de estoque
Pronto para Envio
Não temos muito estoque disponível
Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
Visite Nossa LojaDetalhes do produto
Descrição
Descrição
A fast 2 GB RAM Chip for laptops
Compatibilidade
Compatibilidade
Especificações
Especificações
Compatibilidade
Mostrar mais 6 dispositivos
Ocultar 6 dispositivos
Histórias de Reparos
Macbook was slow.
The iMac needed a RAM upgrade before it could get Mac OSX 10.11 installed.
The repair went well. A simple screwdriver to remove the cover and then I inserted RAM into the empty slot.
Removing the memory that was in the computer was difficult. This required a needle-nose pliers or something that can grab the chip. You cannot remove it with just fingers.
Removing the memory that was in the computer was difficult. This required a needle-nose pliers or something that can gr . . .
Changement de la RAM pour accélération des performances
Très bien.
Prendre garde pour l'iMac blanc de bien remettre les clapets latéraux des barattes de RAM, avant de remettre les barrettes de RAM en position. Sinon vous ne pourrez plus les ressortir !
Someone here was throwing away an iMac because the screen was broken. I picked it and found I could replace the screen for $89. I let the original owner know, but he said it was too old for him. So I ordered some additional memory and an Hybrid SSD 1 TB drive as well. Yeah! I am now windowless at home!
At first I was worried I bought the wrong hard drive, but then I remembered how specific the web site was; pretty sure I got the right thing. (I did)
Check this web site before you throw something away!!
Someone here was throwing away an iMac because the screen was broken. I picked it and found I could replace the screen for $89. I let the original owner know, but he said it was too old for him. So I ordered some additional memory and an Hybrid SSD 1 TB drive as well. Yeah! I am now windowless at ho . . .
The machine only had 1 GB Ram installed
Easy : just follow the guide step by step
Don't worry, just take your time to follow each step.
My harddrive broke so I had to change it.
The repair was REALLY easy and fast! No problems and now my computer is working better than ever because I put more memory in. I also got all my files and programs back because I had made backup with time machine. It was almost too easy:)
I was taking the computer to a mac repair store, but then I found the ifixit page. The repair looked so easy I gave it a try and it worked perfectly!
I was taking the comp . . .
Old macmini on my shelf
Good repair except I didnt insert the RAM far enough. I just needed to push a bit harder to get it inserted properly.
My suggestion is to recommend to buyers of RAM is to buy two sticks. I had two slots in my mac mini and I only purchased one stick. Now that it's over I wish I had bought two.
Buy two sticks of RAM.
My suggestion is to recommend to buyers of RAM is to buy two sticks. I had two slots in my mac mini and I only purchased one stick. Now that it's over I wish . . .
I had 2 gigs of RAM and needed more speed for my 2008 Mac desktop. A friend of mine that's a whiz with Macs sent me your link. I ordered 2 2GB RAM chips, printed out your directions for installation and it was a snap.
It went without a hitch. It was extremely easy. Thank you!!!!!! Now my computer is fast. It feels like I just purchased a brad new Mac.
Go for it.
It went without a hitch. It was extremely easy. Thank you!!!!!! Now my computer . . .
First time replacing the RAM in a Macbook and thank god! It need it!
It was smooth and simple! Take the battery off then punch out the old and swap with the new.
Just the usual: discharge any electric charge, disconnect the battery and power source, get to work and get back at it!
Yes
Good
No
Mostrar mais
Mostrar menos
Quem comprou também levou
