Ir para o conteúdo principal
IBM Thinkpad T61 RAM Replacement
O que você precisa
    1. IBM Thinkpad T61 RAM Replacement, Battery: passo 1, imagem 1 %32
      • Ensure the laptop has been properly shut down and unplugged.
      • Turn the computer over so that you can see the battery release tab located near the top of the Thinkpad.
      Pergunte ao FixBot
      Comentar
    2. IBM Thinkpad T61 RAM Replacement: passo 2, imagem 1 %32
      • Use your finger to slide the release tab to the unlocked symbol.
      Pergunte ao FixBot
      Comentar
    3. IBM Thinkpad T61 RAM Replacement: passo 3, imagem 1 %32 IBM Thinkpad T61 RAM Replacement: passo 3, imagem 2 %32 IBM Thinkpad T61 RAM Replacement: passo 3, imagem 3 %32
      • Hold the tab in the unlocked position and push the battery away from the computer to remove it.
      Pergunte ao FixBot
      Comentar
    4. IBM Thinkpad T61 RAM Replacement: passo 4, imagem 1 %32
      • Slide the new battery in until it clicks.
      • Ensure that the release tab is in the locked position.
      Pergunte ao FixBot
      Comentar
    1. IBM Thinkpad T61 RAM Replacement, RAM: passo 5, imagem 1 %32
      • Using a #0 Phillips screwdriver, remove four 17.0mm screws on the back of the computer.
      • These screws have a RAM symbol next to them.
      Pergunte ao FixBot
      Comentar
    2. IBM Thinkpad T61 RAM Replacement: passo 6, imagem 1 %32
      • Flip back over and open the laptop.
      • Lift up on the inside front panel just below the edge of the keyboard.
      Pergunte ao FixBot
      Comentar
    3. IBM Thinkpad T61 RAM Replacement: passo 7, imagem 1 %32
      • The green rectangles under the front panel are the RAM.
      Pergunte ao FixBot
      Comentar
    4. IBM Thinkpad T61 RAM Replacement: passo 8, imagem 1 %32 IBM Thinkpad T61 RAM Replacement: passo 8, imagem 2 %32 IBM Thinkpad T61 RAM Replacement: passo 8, imagem 3 %32
      • Press out on the two tabs on either side of the ram at the same time.
      • The RAM will release and pop up at a 25 degree angle.
      Pergunte ao FixBot
      Comentar
    5. IBM Thinkpad T61 RAM Replacement: passo 9, imagem 1 %32
      • Pull the RAM away from the housing to remove.
      Pergunte ao FixBot
      Comentar
Conclusão
15 outras pessoas executaram este guia.
Kyle
Membro desde: 04/18/13
479 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 8-58, Johann Spring 2013 Membro de Cal Poly, Team 8-58, Johann Spring 2013
CPSU-JOHANN-S13S8G58
4 Membros
Autoria de 30 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 54
Ao todo: 10,272
