Ir para o conteúdo principal
Asus Eee PC 900 RAM Replacement
O que você precisa
  1. Asus Eee PC 900 RAM Replacement, Battery: passo 1, imagem 1 %32 Asus Eee PC 900 RAM Replacement, Battery: passo 1, imagem 2 %32 Asus Eee PC 900 RAM Replacement, Battery: passo 1, imagem 3 %32
    • Slide the battery's locking tabs from the locked position to unlocked positions.
    • The right tab is unlocked when a red dot is showing.
    • The left tab will have to be held in the unlocked position in order to release the battery.
    Pergunte ao FixBot
    Comentar
  2. Asus Eee PC 900 RAM Replacement: passo 2, imagem 1 %32
    • Slide the battery out while holding the left locking tab in the unlocked position.
    Pergunte ao FixBot
    Comentar
  3. Asus Eee PC 900 RAM Replacement, RAM: passo 3, imagem 1 %32 Asus Eee PC 900 RAM Replacement, RAM: passo 3, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Remove the sticker from the RAM compartment using a pair of tweezers.
    Pergunte ao FixBot
    Comentar
  4. Asus Eee PC 900 RAM Replacement: passo 4, imagem 1 %32 Asus Eee PC 900 RAM Replacement: passo 4, imagem 2 %32
    • Remove the two 4.8 mm screws using a Phillips #0 screwdriver.
    Pergunte ao FixBot
    Comentar
  5. Asus Eee PC 900 RAM Replacement: passo 5, imagem 1 %32
    • Open up the cover from the bottom by carefully prying it open with a plastic opening tool.
    • Be gentle when prying open the cover in order to not damage it.
    Pergunte ao FixBot
    Comentar
  6. Asus Eee PC 900 RAM Replacement: passo 6, imagem 1 %32
    • Remove the back cover by pulling up on the side that had the screws.
    Pergunte ao FixBot
    Comentar
  7. Asus Eee PC 900 RAM Replacement: passo 7, imagem 1 %32 Asus Eee PC 900 RAM Replacement: passo 7, imagem 2 %32
    • Use a spudger to push the top of the pin on the right towards the right (so it isn't holding the RAM chip).
    • Do the same for the left pin. Push the top of the pin towards the left.
    • The RAM should pop up.
    Pergunte ao FixBot
    Comentar
  8. Asus Eee PC 900 RAM Replacement: passo 8, imagem 1 %32
    • Remove the RAM chip by grabbing the top of the chip and pulling it upwards.
    • Be gentle when removing the RAM because it is a very delicate part and you do not want to break any of the pins in the computer.
    Pergunte ao FixBot
    Comentar
Conclusão
5 outras pessoas executaram este guia.
Brian Carreon
Membro desde: 01/25/12
300 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 3-27, Amido Winter 2012 Membro de Cal Poly, Team 3-27, Amido Winter 2012
CPSU-AMIDO-W12S3G27
4 Membros
Autoria de 16 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 43
Ao todo: 9,815
