Ir para o conteúdo principal
iRobot Braava 320 Battery  Replacement
bradley boardwine
bradley boardwine e 2 outros colaboradores
Última atualização em August 28, 2022
1 - 2 minutos
Muito fácil
Introdução
Ir para o passo 1
The battery is an essential component to the iRobot Braava 320. Without a functioning battery, your iRobot could have trouble turning on, staying on, or charging. Replacing the battery may solve these issues.
O que você precisa
  1. iRobot Braava 320 Battery  Replacement, Battery: passo 1, imagem 1 %32
    • Flip your device over and locate the battery cover.
    • The battery cover is located in the center of the device in between both wheels.
  2. iRobot Braava 320 Battery  Replacement: passo 2, imagem 1 %32
    • Using a Flathead #4 screwdriver, gently turn the 12mm screw that holds the battery cover in.
    • The screw does not remove, it stays attached to the cover.
  3. iRobot Braava 320 Battery  Replacement: passo 3, imagem 1 %32 iRobot Braava 320 Battery  Replacement: passo 3, imagem 2 %32
    • Gently remove the battery from the tray and disconnect the battery cable.
    • To remove the battery, pull it straight up. To disconnect the cable, gently pull it straight out of the connector.
    • To reinstall the cable, hold it near the end and gently push it in the connector.
Conclusão
Uma outra pessoa concluiu este guia.
bradley boardwine
Membro desde: 02/28/17
222 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team S1-G3, Nance Spring 2017 Membro de USF Tampa, Team S1-G3, Nance Spring 2017
USFT-NANCE-S17S1G3
4 Membros
Autoria de 10 guias
1Comentário do guia
where do I get a new battery from?
j.svetlova - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 7
Ao todo: 4,868
