Ir para o conteúdo principal
iPod Shuffle 4th Generation Belt Clip Replacement
Andrew Bookholt
Andrew Bookholt e 5 outros colaboradores
Última atualização em October 8, 2024
5 - 30 minutos
Moderado
Introdução
Ir para o passo 1
Replace your Shuffle's belt clip.
O que você precisa
Ferramentas
Exibir mais…
  1. iPod Shuffle 4th Generation Belt Clip Replacement, Rear Panel: passo 1, imagem 1 %32
    • Accessing the internals of the 4th generation Shuffle is extremely difficult, as the rear panel is both glued to the front case and secured by metal retaining clips. It is highly unlikely that you will be able to remove the rear panel without inflicting cosmetic and/or structural damage.
    • Before proceeding, be sure your Shuffle is switched off.
  2. iPod Shuffle 4th Generation Belt Clip Replacement: passo 2, imagem 1 %32 iPod Shuffle 4th Generation Belt Clip Replacement: passo 2, imagem 2 %32
    • Use a combination of iPod opening tools and metal spudgers to pry the rear panel away from the Shuffle by the seam nearest the ON/OFF switch.
    I managed to open mine using no tools at all so without damage. Maybe the glue also weakened over time so might need to use some heat. I didn’t but then again it’s a second hand, old device in my case.
    I used the clip on the back as a leverage to (ever so slightly) bend the back piece in the center. Having that bend is enough for the very small clips on the power switch side to detach. Once that side is removed you can slide the complete back out towards the direction of the power switch. I checked on a flat surface and the piece isn’t damaged, still straight. Just don’t keep it bend too long and don’t over bend it. It really shouldn’t take much since those notches are really small.
    To close it again just slide the back side in again and then snap the power switch side back in place by lightly pressing it on top. Since the clips aren’t damaged this way it will close up nicely. If the notches got damaged you’ll have to use glue instead (hot glue will do and is easily removable again).
    Ha ns - Responder
    what do you mean by bend the back piece in the center?! How do you do that exactly? Did you stick something in between the back piece and the clip and press in?
    Jackson Chan - Responder
    I completely agree with Ha ns' comment. I really cannot understand how the author managed to open this device as described. There must be something like a 0.1mm gap between the housing and the cover, impossible to enter a spudger or pry tool. Use a lever on the hinged side of the clip to lift the cover, insert a 0.2mm plastic film or a thin plectrum or spudger on the bent center of the cover. Avoid to push the spudger down, as there are electronic components underneath, only lift the cover, without overbending. Move over to the side of the on/off switch, and release the 3 clips. On the other end an 8mm long nose will avoid lifting off the cover. You will have to slide it out horizontally. Clearly: you have to be very very careful and gifted...
    cloclolulu - Responder
  3. iPod Shuffle 4th Generation Belt Clip Replacement: passo 3, imagem 1 %32
    • Remove the rear panel from the Shuffle.
  4. iPod Shuffle 4th Generation Belt Clip Replacement, Belt Clip: passo 4, imagem 1 %32
    • Remove the four Phillips screws securing the belt clip to the rear panel.
    • To avoid bending the last two screws, be sure to squeeze the belt clip against the rear panel as you remove them.
  5. iPod Shuffle 4th Generation Belt Clip Replacement: passo 5, imagem 1 %32
    • Remove the belt clip from the rear panel.
    • When reinstalling the screws, be sure to firmly squeeze the belt clip against the rear case until all screws are tightened.
Conclusão
9 outras pessoas executaram este guia.
3 comentários
I'm gonna try to remove the back cover with minimal prying to reduce cosmetic defects. The plan is to somehow remove the spring loaded clip by pushing out the lever pin, then drilling holes along the edge of the over wherre the 3 little hooks are (In this image, where the right thumb is touching. https://d3nevzfk7ii3be.cloudfront.net/ig...).
It would be great if someone could provide a closer look at where exactly the hooks are so I can position my 1.5mm drill bit better. Also, if you can to figure out how to remove the spring loaded clip mechanism without going through the 4 screws, that'd be awesome! I suspect the pin is held in place by just adhesive, but don't want to risk pushing too hard and causing defects. :(
Sam Waiban - Responder
Is it possible to just push the "pin" through to remove the clip? I want to paint my Ipod and want the clip removed to do so.
Inner Circle - Responder
is it possible to remove the back cover by pulling the clip outside? i just want not to damage the back cover clips.
Muhammad Usman Lashari - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 14
Últimos 30 dias: 49
Ao todo: 16,467
