Ir para o conteúdo principal
iPhone 7 Lightning Connector Assembly Replacement
O que você precisa
Vídeo de Apresentação
  1. iPhone 7 Lightning Connector Assembly Replacement, Pentalobe Screws: passo 1, imagem 1 %32
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm pentalobe screws on the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
    Pergunte ao FixBot
    Comentar
  2. iPhone 7 Lightning Connector Assembly Replacement, Mark your opening picks: passo 2, imagem 1 %32 iPhone 7 Lightning Connector Assembly Replacement, Mark your opening picks: passo 2, imagem 2 %32 iPhone 7 Lightning Connector Assembly Replacement, Mark your opening picks: passo 2, imagem 3 %32
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Pergunte ao FixBot
    Comentar
  3. iPhone 7 Lightning Connector Assembly Replacement, Anti-Clamp instructions: passo 3, imagem 1 %32 iPhone 7 Lightning Connector Assembly Replacement, Anti-Clamp instructions: passo 3, imagem 2 %32 iPhone 7 Lightning Connector Assembly Replacement, Anti-Clamp instructions: passo 3, imagem 3 %32
    Ferramenta utilizada neste passo:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
    Pergunte ao FixBot
    Comentar
  4. iPhone 7 Lightning Connector Assembly Replacement: passo 4, imagem 1 %32 iPhone 7 Lightning Connector Assembly Replacement: passo 4, imagem 2 %32 iPhone 7 Lightning Connector Assembly Replacement: passo 4, imagem 3 %32
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    Pergunte ao FixBot
    Comentar
  5. iPhone 7 Lightning Connector Assembly Replacement: passo 5, imagem 1 %32 iPhone 7 Lightning Connector Assembly Replacement: passo 5, imagem 2 %32
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick into the gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
    Pergunte ao FixBot
    Comentar
  6. iPhone 7 Lightning Connector Assembly Replacement, Heat the display: passo 6, imagem 1 %32
    • The next three steps show how to separate the screen using a suction cup.
    • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the phone for about 90 seconds in order to soften up the adhesive underneath.
    Pergunte ao FixBot
    Comentar
  7. iPhone 7 Lightning Connector Assembly Replacement, Separate the display: passo 7, imagem 1 %32 iPhone 7 Lightning Connector Assembly Replacement, Separate the display: passo 7, imagem 2 %32
    • Apply a suction cup to the lower half of the front panel, just above the home button.
    • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
    Pergunte ao FixBot
    Comentar
  8. iPhone 7 Lightning Connector Assembly Replacement: passo 8, imagem 1 %32 iPhone 7 Lightning Connector Assembly Replacement: passo 8, imagem 2 %32 iPhone 7 Lightning Connector Assembly Replacement: passo 8, imagem 3 %32
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
    • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
    Pergunte ao FixBot
    Comentar
  9. iPhone 7 Lightning Connector Assembly Replacement: passo 9, imagem 1 %32 iPhone 7 Lightning Connector Assembly Replacement: passo 9, imagem 2 %32 iPhone 7 Lightning Connector Assembly Replacement: passo 9, imagem 3 %32
    • Slide the opening pick up the left edge of the phone starting at the lower edge and moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
    • Stop near the top left corner of the display.
    • Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
    Pergunte ao FixBot
    Comentar
  10. iPhone 7 Lightning Connector Assembly Replacement, Screen information: passo 10, imagem 1 %32
    • There are delicate cables along the right edge of your iPhone. Don't insert your pick here, as you may damage the cables.
    Pergunte ao FixBot
    Comentar
  11. iPhone 7 Lightning Connector Assembly Replacement: passo 11, imagem 1 %32 iPhone 7 Lightning Connector Assembly Replacement: passo 11, imagem 2 %32 iPhone 7 Lightning Connector Assembly Replacement: passo 11, imagem 3 %32
    • Re-insert your tool at the lower right corner of the iPhone, and slide it around the corner and up the right side of the phone to separate the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the display cables.
    Pergunte ao FixBot
    Comentar
  12. iPhone 7 Lightning Connector Assembly Replacement: passo 12, imagem 1 %32 iPhone 7 Lightning Connector Assembly Replacement: passo 12, imagem 2 %32
    • Gently pull up on the suction cup to lift up the bottom edge of the display.
    • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
    • Pull on the small nub on the suction cup to remove it from the front panel.
    Pergunte ao FixBot
    Comentar
  13. iPhone 7 Lightning Connector Assembly Replacement: passo 13, imagem 1 %32 iPhone 7 Lightning Connector Assembly Replacement: passo 13, imagem 2 %32 iPhone 7 Lightning Connector Assembly Replacement: passo 13, imagem 3 %32
    • Slide an opening pick underneath the display around the top left corner and along the top edge of the phone to loosen the last of the adhesive.
    Pergunte ao FixBot
    Comentar
  14. iPhone 7 Lightning Connector Assembly Replacement: passo 14, imagem 1 %32 iPhone 7 Lightning Connector Assembly Replacement: passo 14, imagem 2 %32
    • Slide the display assembly slightly down (away from the top edge of the phone) to disengage the clips holding it to the rear case.
    Pergunte ao FixBot
    Comentar
  15. iPhone 7 Lightning Connector Assembly Replacement: passo 15, imagem 1 %32 iPhone 7 Lightning Connector Assembly Replacement: passo 15, imagem 2 %32 iPhone 7 Lightning Connector Assembly Replacement: passo 15, imagem 3 %32
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    Pergunte ao FixBot
    Comentar
  16. iPhone 7 Lightning Connector Assembly Replacement, Battery Disconnection: passo 16, imagem 1 %32
    Tri-point Y000 Screwdriver
    $5.99
    Pergunte ao FixBot
    Comentar
  17. iPhone 7 Lightning Connector Assembly Replacement: passo 17, imagem 1 %32
    • Remove the lower connector bracket.
    Pergunte ao FixBot
    Comentar
  18. iPhone 7 Lightning Connector Assembly Replacement: passo 18, imagem 1 %32 iPhone 7 Lightning Connector Assembly Replacement: passo 18, imagem 2 %32 iPhone 7 Lightning Connector Assembly Replacement: passo 18, imagem 3 %32
    • Use the point of a spudger to lift the battery connector out of its socket on the logic board.
    • Bend the connector cable up slightly to prevent it from making contact with the socket and providing power to the phone.
    Pergunte ao FixBot
    Comentar
  19. iPhone 7 Lightning Connector Assembly Replacement, Display Assembly: passo 19, imagem 1 %32 iPhone 7 Lightning Connector Assembly Replacement, Display Assembly: passo 19, imagem 2 %32 iPhone 7 Lightning Connector Assembly Replacement, Display Assembly: passo 19, imagem 3 %32
    • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
    • Use a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
    • To reconnect these cables, press down on one end until it clicks into place, then repeat on the opposite end. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
    • If you have a blank screen, white lines on the display, or partial or complete lack of touch response after reassembling your phone, try disconnecting and carefully reconnecting both of these cables and make sure they are fully seated.
    Pergunte ao FixBot
    Comentar
  20. iPhone 7 Lightning Connector Assembly Replacement: passo 20, imagem 1 %32 iPhone 7 Lightning Connector Assembly Replacement: passo 20, imagem 2 %32 iPhone 7 Lightning Connector Assembly Replacement: passo 20, imagem 3 %32
    • Remove the two 1.3 mm Phillips #000 screws securing the bracket over the front panel sensor assembly connector.
    • Some phones could be Y000. Apple started using Y000 for these at some point in the middle of the product's lifecycle.
    Pergunte ao FixBot
    Comentar
  21. iPhone 7 Lightning Connector Assembly Replacement: passo 21, imagem 1 %32 iPhone 7 Lightning Connector Assembly Replacement: passo 21, imagem 2 %32
    • Disconnect the front panel sensor assembly connector from its socket on the logic board.
    • This press connector should also be reconnected one end at a time to minimize the risk of bending.
    Pergunte ao FixBot
    Comentar
  22. iPhone 7 Lightning Connector Assembly Replacement: passo 22, imagem 1 %32
    Pergunte ao FixBot
    Comentar
  23. iPhone 7 Lightning Connector Assembly Replacement, Barometric Vent: passo 23, imagem 1 %32
    • Remove the two 1.9 mm Phillips screws securing the barometric vent to the rear case.
    Pergunte ao FixBot
    Comentar
  24. iPhone 7 Lightning Connector Assembly Replacement: passo 24, imagem 1 %32 iPhone 7 Lightning Connector Assembly Replacement: passo 24, imagem 2 %32
    • Remove the vent.
    Pergunte ao FixBot
    Comentar
  25. iPhone 7 Lightning Connector Assembly Replacement, Taptic Engine: passo 25, imagem 1 %32 iPhone 7 Lightning Connector Assembly Replacement, Taptic Engine: passo 25, imagem 2 %32
    • Use the flat end of a spudger to disconnect the Taptic Engine connector from its socket on the logic board.
    Pergunte ao FixBot
    Comentar
  26. iPhone 7 Lightning Connector Assembly Replacement: passo 26, imagem 1 %32
    • Remove the three 1.6 mm Phillips screws securing the Taptic Engine to the rear case.
    Pergunte ao FixBot
    Comentar
  27. iPhone 7 Lightning Connector Assembly Replacement: passo 27, imagem 1 %32 iPhone 7 Lightning Connector Assembly Replacement: passo 27, imagem 2 %32
    • Remove the Taptic Engine.
    Pergunte ao FixBot
    Comentar
  28. iPhone 7 Lightning Connector Assembly Replacement, Speaker Assembly: passo 28, imagem 1 %32
    • Remove the Phillips screw securing the Wi-Fi diversity antenna to the rear case:
    • One 3.2 mm screw
    Pergunte ao FixBot
    Comentar
  29. iPhone 7 Lightning Connector Assembly Replacement: passo 29, imagem 1 %32
    • Remove the following three Phillips screws securing the speaker to the rear case:
    • Two 1.3 mm screws
    • One 2.0 mm screw
    Pergunte ao FixBot
    Comentar
  30. iPhone 7 Lightning Connector Assembly Replacement: passo 30, imagem 1 %32 iPhone 7 Lightning Connector Assembly Replacement: passo 30, imagem 2 %32 iPhone 7 Lightning Connector Assembly Replacement: passo 30, imagem 3 %32
    • Use the point of a spudger to lift the two antenna cable connectors up off of the sockets on the logic board.
    Pergunte ao FixBot
    Comentar
  31. iPhone 7 Lightning Connector Assembly Replacement: passo 31, imagem 1 %32 iPhone 7 Lightning Connector Assembly Replacement: passo 31, imagem 2 %32
    • Use tweezers to derout the antenna cables from their bracket on the logic board.
    Pergunte ao FixBot
    Comentar
  32. iPhone 7 Lightning Connector Assembly Replacement: passo 32, imagem 1 %32 iPhone 7 Lightning Connector Assembly Replacement: passo 32, imagem 2 %32
    • Use tweezers to remove the antenna cables from the clip on the speaker.
    • Make sure to grasp the cable near the clip in order to avoid damaging the cable.
    Pergunte ao FixBot
    Comentar
  33. iPhone 7 Lightning Connector Assembly Replacement: passo 33, imagem 1 %32 iPhone 7 Lightning Connector Assembly Replacement: passo 33, imagem 2 %32
    • Use the tip of a spudger to slide the speaker assembly towards the logic board and off of the rear case.
    Pergunte ao FixBot
    Comentar
  34. iPhone 7 Lightning Connector Assembly Replacement: passo 34, imagem 1 %32
    • Remove the speaker.
    Pergunte ao FixBot
    Comentar
  35. iPhone 7 Lightning Connector Assembly Replacement, SIM Card: passo 35, imagem 1 %32 iPhone 7 Lightning Connector Assembly Replacement, SIM Card: passo 35, imagem 2 %32 iPhone 7 Lightning Connector Assembly Replacement, SIM Card: passo 35, imagem 3 %32
    • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray.
    • Press to eject the tray.
    • This may require a significant amount of force. However, ensure the eject tool is properly aligned beforehand as to not damage the eject mechanism inside the phone.
    • Remove the SIM card tray assembly from the iPhone.
    • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
    Pergunte ao FixBot
    Comentar
  36. iPhone 7 Lightning Connector Assembly Replacement, Logic Board Connectors: passo 36, imagem 1 %32 iPhone 7 Lightning Connector Assembly Replacement, Logic Board Connectors: passo 36, imagem 2 %32
    • Use the flat end of a spudger to disconnect the rear-facing camera connector.
    Pergunte ao FixBot
    Comentar
  37. iPhone 7 Lightning Connector Assembly Replacement: passo 37, imagem 1 %32 iPhone 7 Lightning Connector Assembly Replacement: passo 37, imagem 2 %32
    • Remove the following Phillips screws securing the rear camera bracket to the rear case:
    • One 1.3 mm screw
    • One 2.5 mm screw
    Pergunte ao FixBot
    Comentar
  38. iPhone 7 Lightning Connector Assembly Replacement: passo 38, imagem 1 %32
    • Remove the bracket.
    Pergunte ao FixBot
    Comentar
  39. iPhone 7 Lightning Connector Assembly Replacement: passo 39, imagem 1 %32 iPhone 7 Lightning Connector Assembly Replacement: passo 39, imagem 2 %32
    • Use the pointed end of a spudger to pry up and disconnect the antenna bus connector, just left of the rear camera module.
    Pergunte ao FixBot
    Comentar
  40. iPhone 7 Lightning Connector Assembly Replacement: passo 40, imagem 1 %32
    • Remove the two 1.2 mm tri-point screws securing the upper cable bracket.
    Pergunte ao FixBot
    Comentar
  41. iPhone 7 Lightning Connector Assembly Replacement: passo 41, imagem 1 %32 iPhone 7 Lightning Connector Assembly Replacement: passo 41, imagem 2 %32
    • Remove the upper cable bracket.
    Pergunte ao FixBot
    Comentar
  42. iPhone 7 Lightning Connector Assembly Replacement: passo 42, imagem 1 %32 iPhone 7 Lightning Connector Assembly Replacement: passo 42, imagem 2 %32
    • Use the flat end of a spudger to disconnect the upper cable connector.
    Pergunte ao FixBot
    Comentar
  43. iPhone 7 Lightning Connector Assembly Replacement: passo 43, imagem 1 %32 iPhone 7 Lightning Connector Assembly Replacement: passo 43, imagem 2 %32
    • Remove the four Phillips screws securing the Wi-Fi antenna:
    • Three 1.2 mm screws
    • One 1.7 mm screw
    Pergunte ao FixBot
    Comentar
  44. iPhone 7 Lightning Connector Assembly Replacement: passo 44, imagem 1 %32 iPhone 7 Lightning Connector Assembly Replacement: passo 44, imagem 2 %32
    • Remove the top left antenna.
    Pergunte ao FixBot
    Comentar
  45. iPhone 7 Lightning Connector Assembly Replacement: passo 45, imagem 1 %32
    • Remove the following Phillips screws:
    • One 1.3 mm screw
    • One 2.2 mm screw
    Pergunte ao FixBot
    Comentar
  46. iPhone 7 Lightning Connector Assembly Replacement: passo 46, imagem 1 %32 iPhone 7 Lightning Connector Assembly Replacement: passo 46, imagem 2 %32
    Pergunte ao FixBot
    Comentar
  47. iPhone 7 Lightning Connector Assembly Replacement: passo 47, imagem 1 %32
    Standoff Screwdriver for iPhones
    $5.49
    • Remove the 2.2 mm standoff screw from the grounding bracket.
    • Standoff screws are best removed using a standoff screwdriver or bit.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
    Pergunte ao FixBot
    Comentar
  48. iPhone 7 Lightning Connector Assembly Replacement: passo 48, imagem 1 %32 iPhone 7 Lightning Connector Assembly Replacement: passo 48, imagem 2 %32
    • Use tweezers to gently bend the logic board grounding bracket out of the way.
    Pergunte ao FixBot
    Comentar
  49. iPhone 7 Lightning Connector Assembly Replacement, Lightning Connector Assembly: passo 49, imagem 1 %32 iPhone 7 Lightning Connector Assembly Replacement, Lightning Connector Assembly: passo 49, imagem 2 %32
    • Use the point of a spudger to disconnect the lower cable connector.
    Pergunte ao FixBot
    Comentar
  50. iPhone 7 Lightning Connector Assembly Replacement: passo 50, imagem 1 %32
    $5.49
    • Remove the following screws:
    • One 1.4 mm Phillips screw
    • Three 2.2 mm standoff screws
    Pergunte ao FixBot
    Comentar
  51. iPhone 7 Lightning Connector Assembly Replacement: passo 51, imagem 1 %32 iPhone 7 Lightning Connector Assembly Replacement: passo 51, imagem 2 %32
    • Use the point of a spudger to move the SIM card eject plunger out of the logic board's way.
    Pergunte ao FixBot
    Comentar
  52. iPhone 7 Lightning Connector Assembly Replacement: passo 52, imagem 1 %32 iPhone 7 Lightning Connector Assembly Replacement: passo 52, imagem 2 %32
    • Use the flat end of a spudger to gently lift the battery connector end of the logic board up.
    • Make sure you're not pulling against any cables. If you feel resistance, check all cables, connectors, and components are clear of the board.
    Pergunte ao FixBot
    Comentar
  53. iPhone 7 Lightning Connector Assembly Replacement: passo 53, imagem 1 %32 iPhone 7 Lightning Connector Assembly Replacement: passo 53, imagem 2 %32 iPhone 7 Lightning Connector Assembly Replacement: passo 53, imagem 3 %32
    • Lift the battery connector end of the logic board and pull it up and out of the rear case.
    • Be careful not to snag the logic board on any cables.
    Pergunte ao FixBot
    Comentar
  54. iPhone 7 Lightning Connector Assembly Replacement: passo 54, imagem 1 %32
    • Remove the 2.9 mm Phillips screw from the lightning connector.
    Pergunte ao FixBot
    Comentar
  55. iPhone 7 Lightning Connector Assembly Replacement: passo 55, imagem 1 %32 iPhone 7 Lightning Connector Assembly Replacement: passo 55, imagem 2 %32
    • Remove the spring contact from the lightning connector.
    Pergunte ao FixBot
    Comentar
  56. iPhone 7 Lightning Connector Assembly Replacement: passo 56, imagem 1 %32
    • Remove the two 1.6 mm Phillips screws securing the lightning connector cable in place.
    Pergunte ao FixBot
    Comentar
  57. iPhone 7 Lightning Connector Assembly Replacement: passo 57, imagem 1 %32 iPhone 7 Lightning Connector Assembly Replacement: passo 57, imagem 2 %32 iPhone 7 Lightning Connector Assembly Replacement: passo 57, imagem 3 %32
    • Remove the two stickers covering the screws that secure the lightning connector to the bottom of the rear case.
    Pergunte ao FixBot
    Comentar
  58. iPhone 7 Lightning Connector Assembly Replacement: passo 58, imagem 1 %32
    • Remove the two 1.3 mm Phillips screws from the rear case.
    Pergunte ao FixBot
    Comentar
  59. iPhone 7 Lightning Connector Assembly Replacement: passo 59, imagem 1 %32 iPhone 7 Lightning Connector Assembly Replacement: passo 59, imagem 2 %32
    • Use the pointed end of a spudger to separate the two microphones from the bottom of the rear case.
    Pergunte ao FixBot
    Comentar
  60. iPhone 7 Lightning Connector Assembly Replacement: passo 60, imagem 1 %32
    • Heating the lower edge of the iPhone will help soften the adhesive securing Lightning connector cable, making it easier to remove.
    • Use a hairdryer or reheat your iOpener to heat the lower edge of the phone.
    • Wait for about a minute, allowing the adhesive to warm up before proceeding to the next step.
    Pergunte ao FixBot
    Comentar
  61. iPhone 7 Lightning Connector Assembly Replacement: passo 61, imagem 1 %32 iPhone 7 Lightning Connector Assembly Replacement: passo 61, imagem 2 %32 iPhone 7 Lightning Connector Assembly Replacement: passo 61, imagem 3 %32
    • Starting from the middle of the phone, slide an opening pick underneath the lightning connector to separate it from the rear case.
    Pergunte ao FixBot
    Comentar
  62. iPhone 7 Lightning Connector Assembly Replacement: passo 62, imagem 1 %32 iPhone 7 Lightning Connector Assembly Replacement: passo 62, imagem 2 %32 iPhone 7 Lightning Connector Assembly Replacement: passo 62, imagem 3 %32
    • Continue to slide the pick towards the lightning connector to further separate the assembly from the rear case.
    Pergunte ao FixBot
    Comentar
  63. iPhone 7 Lightning Connector Assembly Replacement: passo 63, imagem 1 %32 iPhone 7 Lightning Connector Assembly Replacement: passo 63, imagem 2 %32
    • Continue to slide the pick underneath the lightning connecter assembly.
    • Stop sliding the pick once it passes the battery.
    Pergunte ao FixBot
    Comentar
  64. iPhone 7 Lightning Connector Assembly Replacement: passo 64, imagem 1 %32 iPhone 7 Lightning Connector Assembly Replacement: passo 64, imagem 2 %32 iPhone 7 Lightning Connector Assembly Replacement: passo 64, imagem 3 %32
    • Starting at the corner of the phone, slide the pick underneath the assembly towards the lightning connector.
    • Stop sliding the pick when it reaches the lightning connector.
    Pergunte ao FixBot
    Comentar
  65. iPhone 7 Lightning Connector Assembly Replacement: passo 65, imagem 1 %32 iPhone 7 Lightning Connector Assembly Replacement: passo 65, imagem 2 %32
    • Gently pull the lightning connector out of its hole on the rear case.
    Pergunte ao FixBot
    Comentar
  66. iPhone 7 Lightning Connector Assembly Replacement: passo 66, imagem 1 %32 iPhone 7 Lightning Connector Assembly Replacement: passo 66, imagem 2 %32
    • Slide a pick below the lightning connector to further separate the lightning connector assembly from the rear case.
    • Continue to slide the pick until the lightning connector assembly is no longer adhered to the rear case.
    Pergunte ao FixBot
    Comentar
  67. iPhone 7 Lightning Connector Assembly Replacement: passo 67, imagem 1 %32 iPhone 7 Lightning Connector Assembly Replacement: passo 67, imagem 2 %32 iPhone 7 Lightning Connector Assembly Replacement: passo 67, imagem 3 %32
    • Remove the lightning connector assembly.
    • Before installing or replacing the Lightning connector assembly:
    • Use a plastic tool to scour any bits of adhesive residue from the rear case.
    • Make sure the Lightning connector assembly is correctly positioned so that the two white dots on the iPhone's rear case show through the two circular cutouts in the Lightning flex cable. If they don't, the flex cable will remain misaligned and you won't be able to reconnect it to its socket on the logic board.
    Pergunte ao FixBot
    Comentar
  68. iPhone 7 Lightning Connector Assembly Replacement: passo 68, imagem 1 %32 iPhone 7 Lightning Connector Assembly Replacement: passo 68, imagem 2 %32 iPhone 7 Lightning Connector Assembly Replacement: passo 68, imagem 3 %32
    • A rubber gasket on the bottom of the Lightning connector protects your iPhone from liquid and dust intrusion. If you are installing a new Lightning connector assembly, you may need to carefully remove and transfer the gasket to the new part.
    • The small adhesive patch on the bottom of each microphone also protects your iPhone from liquid and dust intrusion. For best results, replace the two adhesive patches before installing your Lightning connector assembly.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your device, follow these instructions in reverse order. Don't forget to reapply the display adhesive before reinstalling the display.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 7 Answers community for troubleshooting help.
284 outras pessoas executaram este guia.
Scott Havard
Membro desde: 06/27/16
51.299 Reputação
Autoria de 31 guias
54Comentários do guia
The old ones were so easy! Why did Apple have to put the thing under the board!!!???
Christopher Crawford - Responder Compartilhar
Prob to discourage people from replacing it themselves instead of sending to apple
Elwen Omara - Responder Compartilhar
I dunno. It was a pain, but surprisingly I got mine fixed. When I took it to the apple store they flat out told me that they wouldn’t fix it at all. I couldn’t even send it in to them. Something about no communication with the logic board and they refused to touch it. Thankfully the guides are detailed enough for goofs like me to be successful.
Ray Bieze - Responder Compartilhar
Ho un problema dopo aver installato il nuovo connettore. Quando l’iphone e scarico, inserendo il cavo, appare sul display il simbolo batteria. Una volta acceso il cavo non viene più segnalato e la ricarica non continua. Cosa può essere?
Fabio - Responder Compartilhar
Salve ho lo stesso problema,qual è il problema?
lorenzo Serra - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 22
Últimos 7 dias: 136
Últimos 30 dias: 1,289
Ao todo: 468,126
