Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass.
Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
Power off your iPhone before beginning disassembly.
Remove the two 3.8 mm P2 Pentalobe screws on either side of the Lightning connector.
Ferramenta utilizada nesse passo:iSclack$24.99-
Close the handle on the iSclack, opening the suction-cup jaws.
Place the bottom of your iPhone in between the suction cups, against the plastic depth gauge.
The top suction cup should rest just above the home button.
Open the handles to close the jaws of the iSclack. Center the suction cups and press them firmly onto the top and bottom of the iPhone.
Hold onto your iPhone securely and close the handle of the iSclack to separate the suction cups, pulling the front panel up from the rear case.
The iSclack is designed to safely open your iPhone just enough to separate the pieces, but not enough to damage any cables.
Skip the next three steps and continue on to Step 8.
Press a suction cup onto the screen, just above the home button.
While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
With a plastic opening tool, begin to gently pry the rear case down, away from the display assembly, while you pull up with the suction cup.
Pull the plastic nub to release the vacuum seal on the suction cup.
Remove the suction cup from the display assembly.
Lift the home button end of the front panel up to gain access to the connectors near the top of the phone.
Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
In a pinch, you can use an unopened canned beverage to hold the display.
Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
Remove the two 1.6 mm Phillips #000 screws securing the metal battery connector bracket to the logic board.
Remove the metal battery connector bracket from the iPhone.
Use a spudger or a clean fingernail to gently pry the battery connector up from its socket on the logic board.
Remove the following Phillips #000 screws securing the front panel assembly cable bracket to the logic board:
Two 1.3 mm screws
One 1.7 mm screw
One 3.25 mm screw
Remove the front panel assembly cable bracket from the logic board.
Use a plastic opening tool or a fingernail to disconnect the front-facing camera and sensor cable connector.
Use a plastic opening tool or a fingernail to disconnect the LCD cable connector.
Remove the front panel assembly from the rear case.
Run the tip of a spudger between the battery and the headphone jack to unfold the battery adhesive tab.
Cut the black battery adhesive tab between the two white adhesive strips, separating them.
Slowly pull one of the battery adhesive strips away from the battery, toward the bottom of the iPhone.
Pull steadily, maintaining constant tension on the strip as it slips out from between the battery and the rear case. For best results, pull the strip at a 60º angle or less.
Guide the strip carefully around the corner and up the side of the battery. Be careful not to snag it on any of the other internal iPhone components.
Ferramenta utilizada nesse passo:Plastic Cards$2.99-
Apply a few drops of isopropyl alcohol (90% or greater) under the battery and let it flow around the adhesive to help weaken it. High concentration isopropyl alcohol acts as a solvent and dries without leaving any residue, so it will not hurt your iPhone.
Carefully wedge a plastic card under the battery on the side nearest the logic board.
Slide the card from the top of the battery to the bottom, pushing toward the edge of the case.
If the battery is still stuck to the case, follow our iOpener heating instructions or use a hair dryer to heat the adhesive securing your battery to the rear case.
Lay the iOpener flat on the backside of the iPhone to the right of the camera. Smooth it out so that there is good contact between the back of the iPhone and the iOpener.
Let the bag sit on the iPhone for approximately 90 seconds before attempting to remove the battery.
If using a hair dryer or heat gun, heat the back of the iPhone until it's slightly too hot to touch.
Lift and remove the battery from the iPhone.
Adhere the battery, disconnect it, and continue reassembling your device.
Use a plastic opening tool to peel the home button spring contact cable up from the speaker enclosure.
Remove the following screws securing the speaker enclosure to the rear case:
Two 2.7 mm Phillips #000 screws
One 2.2 mm Phillips #000 screw
Use the flat end of a spudger to gently pry the speaker enclosure up from the rear case.
Remove the speaker enclosure. Be careful not to snag it on the antenna cable.
Use a plastic opening tool to disconnect the Lightning connector ribbon cable from its socket on the logic board.
The Lightning connector cable is lightly adhered to a shield on the logic board. Use the flat end of a spudger to gently peel the cable up.
Disconnect the cellular antenna connector from the base of the logic board.
Remove the following screws securing the Lightning connector to the rear case:
Two 3.4 mm Phillips #000 screws
One 2.7 mm Phillips #000 screw
Gently peel the Lightning connector assembly up from the rear case.
You may need to use the flat end of a spudger to completely free the assembly.
Remove the Lightning connector assembly.
There is a small rubber gasket attached to the microphone. Be sure to transfer it to the new assembly.
147 outras pessoas executaram este guia.
22 comentários
I fix it. Tomorrow I was got my packet from ifixit.com with lightning assembly and today my iPhone 5c can charge again.
And I would like to tell you several words about a process:
1. Thanks Ifixit for the tools - pentalope screwdriver and a magnet mat - it was great
2. All was simple with a step by step instructions on site.
3. IMPORTANT!!!! Unnecessary to remove a battery before the Lightning assembly replace - replacement possible without it)))
4. Don't forget to remove a rubber head from an old microphone - new hasn't such part.
5. Don't forget to lay an antenna cable properly when install a speaker back.
6. All the parts are very small - a magnifying glass required)))
7. I was made it for 1 hour )))
THOSE CHANGING JUST THE DOCK CONNECTOR!
Important! Steps 14, 15, and 19 through 28 are totally unnecessary. The SIM card is fine where it is, and the battery does not need to be removed to access everything. I would recommend disconnecting the battery connector while working, however.
Also, be careful with the little antenna where it connects to the dock connector flex. Mine broke off and had to be resoldered, but I bought the part on eBay.
Thanks for your feedback! We went ahead and removed the SIM card steps. It may be helpful to remove the battery in order to get enough clearance to separate the Lightning cable assembly from the rear case, but folks are certainly welcome to skip those steps if they are comfortable doing so. :)
It is certainly not necessary to remove the battery in order to do this repair. I do not recommend following those steps.
