Ir para o conteúdo principal
iPhone 1st Generation SIM Card Replacement
iRobot
iRobot e 6 outros colaboradores
Última atualização em March 16, 2021
2 minutos
Muito fácil
How to remove the SIM card from the 1st Generation iPhone.
O que você precisa
Peças
Ferramentas
Exibir mais…
  1. iPhone 1st Generation SIM Card Replacement, SIM Card: passo 1, imagem 1 %32
    • Insert a SIM card eject tool or paper clip into the hole next to the headphone jack.
    • Press down on the paper clip until the SIM card tray pops out.
    To remove the SIM, insert the end of a SIM eject tool or a small thin paper clip into the hole on the SIM tray. Press firmly and push the tool straight in until the tray pops out.
    http://support.apple.com/kb/ht1438
    neuronetix - Responder
    I put the SIM card back in, and the slide to unlock does not work.
    dean -
    The only carrier to accept this iPhone was AT&T, they have discontinued use of that baseband. Nobody else in the world except for early renegade reverse engineers such as Geohot can get the device to work as a really old iPod no use unlocking the device because the technology inside the most recently OEM sold/refurbed iPhone 1st gen fails universally. You should only buy a screen assembly and snap it onto the back and call it a dummy phone and put it in a museum.
    Alexander Weinhart - Responder
  2. iPhone 1st Generation SIM Card Replacement: passo 2, imagem 1 %32
    • Grasp the SIM card tray and slide it out of the iPhone.
Conclusão
41 outras pessoas executaram este guia.
iRobot
Membro desde: 09/24/09
1 Reputação
Autoria de 636 guias
7 comentários
thats what i did too. but it froze..
i dont know what to do..
Marie - Responder
Can't access
hope -
Try with a little strap cut out from a radiology exam sheet. Put it inside the sim tray and try to open again. It works.
Henri Salvat - Responder
Does anyone know where I can get a SIM tray and card for the 1st get iPhone model A1203?
TIA
J R Rosen - Responder
Did you ever find an answer for this? I was given a 1st gen iPhone A1203 and it doesn't have a sim card. Thanks.
Alex Omar - Responder
I need a sim card and a sim card holder for 1st Gen iPhone, does anyone know where I can get them?
Gina C. - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 19
Últimos 30 dias: 66
Duração total: 84,275
