Ir para o conteúdo principal
iPad Wi-Fi Logic Board Replacement
Miroslav Djuric
Miroslav Djuric e 8 outros colaboradores
Última atualização em 19 de jun de 2024
Nenhuma estimativa
Moderado
Introdução
Ir para o passo 1
Follow this guide to remove the iPad's logic board.
O que você precisa
Peças
Ferramentas
Exibir mais…
  1. iPad Wi-Fi Logic Board Replacement, Display Assembly: passo 1, imagem 1 %32 iPad Wi-Fi Logic Board Replacement, Display Assembly: passo 1, imagem 2 %32 iPad Wi-Fi Logic Board Replacement, Display Assembly: passo 1, imagem 3 %32
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
    1) Are you recommending to cover the display with clear packing tape even if it is intact (not cracked)?
    2) If so,will the tape take the display’s oleophobic coating with it when removed?
    Mitch Stary - Responder
    Hola necesito comprar
    Alsone Michel - Responder
    Hola, ¿no estoy seguro si te refieres a las gafas de protección o a la pantalla? Te dejo los dos enlaces aquí:
    iPad LCD Panel
    [produto vinculado ausente ou desativado: IF145-125]
    Sandra Hiller -
  2. iPad Wi-Fi Logic Board Replacement: passo 2, imagem 1 %32 iPad Wi-Fi Logic Board Replacement: passo 2, imagem 2 %32
    • In this guide you will be prying the iPad's display assembly away from the aluminum body. Read ahead and follow the directions closely to avoid damaging the display assembly or the fragile clips holding it in place.
    • There are 14 metal clips holding the display assembly in place, shown at left. As you pry in the following steps, do your best to pry around these clips and not slice through them with your opening tool.
    • If you do happen to break some clips, you can buy replacements here.
    A clearer explanation of the orientation is needed here. The bar code is at the top left of the iPad when you are looking at the screen.
    David Hincks - Responder
  3. iPad Wi-Fi Logic Board Replacement: passo 3, imagem 1 %32 iPad Wi-Fi Logic Board Replacement: passo 3, imagem 2 %32
    • Insert a metal spudger between the top edge of the display assembly and the rear panel assembly.
    • Rotate the spudger away from you to release the tabs along the top edge of the display.
    • Insert a second metal spudger between the top edge of the display assembly and the rear panel assembly to keep the tabs from snapping back into place.
    Tip* "ONLY WITH METAL SPUDGER* heat it with a lighter till its warm to touch, then slide it like a butter knife. it reduces chances of chipping glass.
    luckie - Responder
    I've found that by using a thicker iPad tool dents the back less(not at all if your careful) and start prying just under the volume button and working my way down works better as the metal clips are on all sider except the right side.
    richard - Responder
    It would be really helpful to point out where all the clips and tabs are, and to show a picture of them (unbroken), so you know what you're trying to release.
    Styg - Responder
  4. iPad Wi-Fi Logic Board Replacement: passo 4, imagem 1 %32 iPad Wi-Fi Logic Board Replacement: passo 4, imagem 2 %32
    • With one spudger, work your way along the right edge of the iPad.
    • The front panel is held to the aluminum back by metal clips on the top, bottom, and left sides. The right side has plastic tabs which slide into recesses in the backplate.
    • Once the clips are released, lift the left side of the front panel up and slide it to the left to clear the tabs from the aluminum backplate.
    • Pry carefully and gently—if you feel resistance, stop and pry at another spot.
    Its seems easier to undo the clips on the left and bottom by levering them with an iPad tool and pusing the clips in from the edge with another tool when i can visually see them. One the right side, bottom and most of the left side is done there isnt much need to do the top as it will slide off if moved about a centimeter
    richard - Responder
  5. iPad Wi-Fi Logic Board Replacement: passo 5, imagem 1 %32
    • Lift the display assembly away from the rear panel assembly by its bottom edge.
    • Do not attempt to remove the display at this time, as it is attached to the rear panel assembly.
    By it's BOTTOM edge.
    jonathan - Responder
  6. iPad Wi-Fi Logic Board Replacement: passo 6, imagem 1 %32
    • In the following steps, you will disconnect the three cables attaching the display assembly to the logic board. The cables are for the following components:
    • Digitizer
    • Ambient Light Sensor
    • Display Data Cable
    It would be easier to detach the Display Data Cable at its connector on the far right in the picture, since there doesnt seem to be much play to undo the suggested one.
  7. iPad Wi-Fi Logic Board Replacement: passo 7, imagem 1 %32 iPad Wi-Fi Logic Board Replacement: passo 7, imagem 2 %32 iPad Wi-Fi Logic Board Replacement: passo 7, imagem 3 %32
    • Use the edge of a plastic opening tool to flip up the retaining flaps holding the digitizer ribbon cables in their sockets on the logic board.
    • Be sure you are flipping up the retaining flap, not the socket itself.
    • Pull the digitizer ribbon cables straight out of their sockets.
    Adding this comment in its proper place:
    After flipping up the metal retainer, pull it sideways.
    Do not pull it up vertically.
    Joe in PA
  8. iPad Wi-Fi Logic Board Replacement: passo 8, imagem 1 %32
    • Use a plastic opening tool to remove the ambient light sensor connector from its socket by gently prying upward.
  9. iPad Wi-Fi Logic Board Replacement: passo 9, imagem 1 %32 iPad Wi-Fi Logic Board Replacement: passo 9, imagem 2 %32
    • Disconnect the display data cable from the main board by flipping up the metal retainer by its black plastic pull tab.
    • Pull the cable connector away from its socket.
    • Pull the connector parallel to the face of the logic board.
    IMHO, unhooking data display cable from the other end is preferable to the above location, since the cable itself is sealed or taped onto the assembly.
    Roger Buttermore - Responder
  10. iPad Wi-Fi Logic Board Replacement: passo 10, imagem 1 %32
    • Remove the display assembly from the rear panel assembly.
  11. iPad Wi-Fi Logic Board Replacement, Logic Board: passo 11, imagem 1 %32 iPad Wi-Fi Logic Board Replacement, Logic Board: passo 11, imagem 2 %32 iPad Wi-Fi Logic Board Replacement, Logic Board: passo 11, imagem 3 %32
    • Use the edge of a plastic opening tool to:
    • Pry the side button connector up off the logic board from underneath the wires.
    • Pry the speaker connector up off its socket on the logic board from beneath the speaker wires.
    • Carefully flip up the ZIF ribbon cable retaining flap on the socket near the headphone jack.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the headphone jack ribbon cable toward the left side of the iPad to disconnect it from its socket.
    Just skip removing the “side button connector” as you may instead sever the small solder connections to the socket. It’s not a necessary step and is more dangerous than anything.
    Max Powers - Responder
    I wish I had understood your post a little better, the socket popped off of the logic board for me. Is there any way to reconnect it or did I just waste my money trying to fix my own device? Thanks for any suggestions, listen to Max, good advice, there’s no reason to remove that connection and it just puts you in danger of doing what i did. Good luck to all.
    George Pradel - Responder
  12. iPad Wi-Fi Logic Board Replacement: passo 12, imagem 1 %32
    • Remove the following screws securing the logic board to the rear panel assembly.
    • Two 4.56 mm T5 Torx screws.
    • Two 3.76 mm T5 Torx screws.
    确定是T5吗,为什么在这个拆解里是写T4,我都糊涂了
    iPad Wi-Fi Teardown
    keeeeeep - Responder
    red are t5, orange are t4
    Patrick - Responder
  13. iPad Wi-Fi Logic Board Replacement: passo 13, imagem 1 %32 iPad Wi-Fi Logic Board Replacement: passo 13, imagem 2 %32
    • Use the edge of a plastic opening tool to carefully pry the dock cable connector straight up off the logic board.
    • Lift the logic board out of the rear panel assembly.
    Hello, what kind of adhesive should i use when i put the new battery?
    Helyousa - Responder
Conclusão
27 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all
3Comentários do guia
Isn't the firmware containing the serial number on the logic board? If so you would need to add the serial number back in right?
anthonypossnett - Responder
Can I change the logic board from another iPad to this one?
Michael Lombardi - Responder
Hi my gen 5 ipod touch( yep had it forever) screen broke yet that far back replacing that not worth the effort. Want to try and use any hardware it didn't ruin when i sat on it. try to connect to my hp monitor from 2003? Maybe? thanks for reading. cheers
Cooper Grayson - Responder
Comentar
Visualizações:
Últimas 24 horas: 10
Últimos 7 dias: 45
Últimos 30 dias: 179
Ao todo: 64,439
