Ir para o conteúdo principal
iPad 9 LTE Button Control Cable Replacement
O que você precisa
    1. iPad 9  LTE Button Control Cable Replacement, Heat the left edge: passo 1, imagem 1 %32
      • Power down your iPad before beginning the repair.
      • Heat an iOpener and apply it to the left edge of the iPad for two minutes.
      Pergunte ao FixBot
      Comentar
    2. iPad 9  LTE Button Control Cable Replacement, Screen removal information: passo 2, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement, Screen removal information: passo 2, imagem 2 %32 iPad 9  LTE Button Control Cable Replacement, Screen removal information: passo 2, imagem 3 %32
      • While you're waiting for the adhesive to loosen, note the following areas that are sensitive to prying:
      • Front camera
      • Ambient light sensors
      • Antennas
      • Display cables
      Pergunte ao FixBot
      Comentar
    3. iPad 9  LTE Button Control Cable Replacement, Anti-Clamp instructions: passo 3, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement, Anti-Clamp instructions: passo 3, imagem 2 %32 iPad 9  LTE Button Control Cable Replacement, Anti-Clamp instructions: passo 3, imagem 3 %32
      Ferramenta utilizada neste passo:
      Clampy - Anti-Clamp
      $24.95
      • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
      • Place an object under your iPad so it rests level between the suction cups.
      • Position the suction cups near the middle of the left edge—one on the top, and one on the bottom.
      • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
      • If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
      Pergunte ao FixBot
      Comentar
    4. iPad 9  LTE Button Control Cable Replacement: passo 4, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement: passo 4, imagem 2 %32 iPad 9  LTE Button Control Cable Replacement: passo 4, imagem 3 %32
      • Pull the blue handle forward to lock the arms.
      • Turn the handle clockwise 360 degrees or until the cups start to stretch.
      • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
      Pergunte ao FixBot
      Comentar
    5. iPad 9  LTE Button Control Cable Replacement: passo 5, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement: passo 5, imagem 2 %32
      • Wait one minute to give the adhesive a chance to release and present an opening gap.
      • If your screen isn't getting hot enough, you can use a hair dryer to heat along the left edge of the iPad.
      • For complete instructions on how to use a hair dryer, check out this guide.
      • Insert an opening pick under the digitizer when the Anti-Clamp creates a large enough gap.
      • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
      • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
      • Skip the next step.
      Pergunte ao FixBot
      Comentar
    6. iPad 9  LTE Button Control Cable Replacement, Insert an opening pick: passo 6, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement, Insert an opening pick: passo 6, imagem 2 %32 iPad 9  LTE Button Control Cable Replacement, Insert an opening pick: passo 6, imagem 3 %32
      • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
      • Once the screen is warm to touch, apply a suction handle to the left edge of the screen and as close to the edge as possible.
      • Lift the screen with the suction handle to create a small gap between the digitizer and the frame.
      • Insert an opening pick into the gap between the digitizer and the frame.
      Pergunte ao FixBot
      Comentar
    7. iPad 9  LTE Button Control Cable Replacement, Separate the left adhesive: passo 7, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement, Separate the left adhesive: passo 7, imagem 2 %32 iPad 9  LTE Button Control Cable Replacement, Separate the left adhesive: passo 7, imagem 3 %32
      • Insert a second opening pick into the gap you just created.
      • Slide the pick toward the bottom-left corner of the iPad to separate the adhesive.
      • Leave the pick in the bottom-left corner to prevent the adhesive from re-sealing.
      • Don't worry if you can see the opening pick through the digitizer—just pull the pick out. The LCD screen shouldn't be damaged, but you risk leaving behind hard-to-clean adhesive.
      Pergunte ao FixBot
      Comentar
    8. iPad 9  LTE Button Control Cable Replacement: passo 8, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement: passo 8, imagem 2 %32 iPad 9  LTE Button Control Cable Replacement: passo 8, imagem 3 %32
      • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad to continue separating the adhesive.
      Pergunte ao FixBot
      Comentar
    9. iPad 9  LTE Button Control Cable Replacement: passo 9, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement: passo 9, imagem 2 %32 iPad 9  LTE Button Control Cable Replacement: passo 9, imagem 3 %32
      • Slide the first opening pick towards to top-left corner of the iPad to separate the adhesive.
      • Leave the pick in the top-left corner to prevent the adhesive from re-sealing.
      Pergunte ao FixBot
      Comentar
    10. iPad 9  LTE Button Control Cable Replacement, Heat the top edge: passo 10, imagem 1 %32
      • Heat an iOpener and apply it to the top edge of the iPad for two minutes.
      Pergunte ao FixBot
      Comentar
    11. iPad 9  LTE Button Control Cable Replacement, Separate the top left adhesive: passo 11, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement, Separate the top left adhesive: passo 11, imagem 2 %32 iPad 9  LTE Button Control Cable Replacement, Separate the top left adhesive: passo 11, imagem 3 %32
      • Rotate the pick around the top-left corner of the iPad to separate the adhesive.
      • Only insert the pick up to 7 mm to avoid damaging the ambient light sensor.
      Pergunte ao FixBot
      Comentar
    12. iPad 9  LTE Button Control Cable Replacement, Separate the top adhesive: passo 12, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement, Separate the top adhesive: passo 12, imagem 2 %32 iPad 9  LTE Button Control Cable Replacement, Separate the top adhesive: passo 12, imagem 3 %32
      • Slide the opening pick along the top edge of the iPad, stopping just before you reach the front camera.
      • Avoid sliding the pick over the front camera, as you may damage the lens. The following steps will show how to prevent this.
      Pergunte ao FixBot
      Comentar
    13. iPad 9  LTE Button Control Cable Replacement: passo 13, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement: passo 13, imagem 2 %32 iPad 9  LTE Button Control Cable Replacement: passo 13, imagem 3 %32
      • Pull the pick out until only the tip is between the digitizer and the frame.
      • Slide the pick above the front camera to separate the adhesive.
      • Leave the pick near the right side of the front camera before continuing.
      Pergunte ao FixBot
      Comentar
    14. iPad 9  LTE Button Control Cable Replacement: passo 14, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement: passo 14, imagem 2 %32 iPad 9  LTE Button Control Cable Replacement: passo 14, imagem 3 %32
      • Re-insert the pick and slide it towards the top-right corner of the iPad to completely separate the top adhesive.
      • Leave the pick in the top-right corner to prevent the adhesive from re-sealing.
      Pergunte ao FixBot
      Comentar
    15. iPad 9  LTE Button Control Cable Replacement, Heat the right edge: passo 15, imagem 1 %32
      • Heat an iOpener and apply it to the right edge of the iPad for two minutes.
      Pergunte ao FixBot
      Comentar
    16. iPad 9  LTE Button Control Cable Replacement, Separate the top right adhesive: passo 16, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement, Separate the top right adhesive: passo 16, imagem 2 %32 iPad 9  LTE Button Control Cable Replacement, Separate the top right adhesive: passo 16, imagem 3 %32
      • Rotate the pick around the top-right corner of the iPad to separate the adhesive.
      • Only insert the pick up to 4 mm to avoid damaging the ambient light sensor.
      Pergunte ao FixBot
      Comentar
    17. iPad 9  LTE Button Control Cable Replacement, Separate the right adhesive: passo 17, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement, Separate the right adhesive: passo 17, imagem 2 %32 iPad 9  LTE Button Control Cable Replacement, Separate the right adhesive: passo 17, imagem 3 %32
      • Insert a new opening pick and slide it to the middle of the iPad's right edge.
      • The display cables are located approximately halfway from the bottom of the iPad. Stop sliding once you reach three inches from the bottom of the iPad.
      Pergunte ao FixBot
      Comentar
    18. iPad 9  LTE Button Control Cable Replacement, Heat the bottom edge: passo 18, imagem 1 %32
      • Heat an iOpener and apply it to the bottom edge of the iPad for two minutes.
      Pergunte ao FixBot
      Comentar
    19. iPad 9  LTE Button Control Cable Replacement, Separate the bottom left adhesive: passo 19, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement, Separate the bottom left adhesive: passo 19, imagem 2 %32 iPad 9  LTE Button Control Cable Replacement, Separate the bottom left adhesive: passo 19, imagem 3 %32
      • Slide the bottom-left pick to the bottom-left corner to separate the adhesive.
      • Don't fully rotate the pick around the corner, as you may damage the antenna.
      • The third image shows the bottom-left antenna underneath the digitizer.
      • Leave the pick in the corner before moving to the next step.
      Pergunte ao FixBot
      Comentar
    20. iPad 9  LTE Button Control Cable Replacement, Separate the bottom adhesive: passo 20, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement, Separate the bottom adhesive: passo 20, imagem 2 %32 iPad 9  LTE Button Control Cable Replacement, Separate the bottom adhesive: passo 20, imagem 3 %32
      • Insert a new opening pick into the gap you just created on the bottom edge of the iPad.
      • Slide the pick over the antenna, stopping just before the home button.
      • Only slide the pick towards the home button and not away from it, as you may damage the antenna.
      • If you need to slide the pick over this section again, remove and re-insert it at the bottom-left corner.
      • Leave the pick to the left of the home button before continuing.
      Pergunte ao FixBot
      Comentar
    21. iPad 9  LTE Button Control Cable Replacement: passo 21, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement: passo 21, imagem 2 %32 iPad 9  LTE Button Control Cable Replacement: passo 21, imagem 3 %32
      • Insert an opening pick into the gap you just created.
      • Slide the pick underneath the home button and towards the bottom-right corner, making sure only the tip is between the digitizer and the frame.
      Pergunte ao FixBot
      Comentar
    22. iPad 9  LTE Button Control Cable Replacement: passo 22, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement: passo 22, imagem 2 %32 iPad 9  LTE Button Control Cable Replacement: passo 22, imagem 3 %32
      • Re-insert the pick and slide it towards the home button to completely separate the bottom adhesive.
      • If you need to slide the pick over this section again, remove and re-insert it at the bottom-right corner.
      • Leave the pick to the right of the home button before continuing.
      Pergunte ao FixBot
      Comentar
    23. iPad 9  LTE Button Control Cable Replacement, Heat the right edge: passo 23, imagem 1 %32
      Pergunte ao FixBot
      Comentar
    24. iPad 9  LTE Button Control Cable Replacement: passo 24, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement: passo 24, imagem 2 %32
      • Be very careful with this step. Take your time, ensure the adhesive is hot and soft, and make sure you separated all of the adhesive with an opening pick. Don't be afraid to stop and reheat.
      • Twist the two opening picks on the left corners of the iPad to lift the digitizer slightly, separating the the last of the adhesive in the process.
      • If there's a significant amount of resistance, reheat the edges and work along them with an opening pick.
      Pergunte ao FixBot
      Comentar
    25. iPad 9  LTE Button Control Cable Replacement: passo 25, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement: passo 25, imagem 2 %32
      • Lift the left edge of the digitizer upwards to further separate the adhesive along the right edge of the iPad.
      Pergunte ao FixBot
      Comentar
    26. iPad 9  LTE Button Control Cable Replacement, Separate the right adhesive: passo 26, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement, Separate the right adhesive: passo 26, imagem 2 %32 iPad 9  LTE Button Control Cable Replacement, Separate the right adhesive: passo 26, imagem 3 %32
      Pergunte ao FixBot
      Comentar
    27. iPad 9  LTE Button Control Cable Replacement: passo 27, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement: passo 27, imagem 2 %32
      • Once all of the adhesive has been separated, open the digitizer like a book and rest it parallel to the iPad.
      • During reassembly, clean the remaining adhesive from the frame—and the digitizer if you're re-using it—with isopropyl alcohol. Replace the adhesive with our adhesive strips or pre-cut adhesive cards.
      • Be mindful of the display cables when reassembling the iPad. Make sure they are folded properly underneath the LCD screen to prevent any damage.
      Pergunte ao FixBot
      Comentar
    1. iPad 9  LTE Button Control Cable Replacement, Remove the LCD: passo 28, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement, Remove the LCD: passo 28, imagem 2 %32 iPad 9  LTE Button Control Cable Replacement, Remove the LCD: passo 28, imagem 3 %32
      • Use tweezers, or your fingers, to remove any tape covering the LCD screws.
      Pergunte ao FixBot
      Comentar
    2. iPad 9  LTE Button Control Cable Replacement, Unfasten the LCD screen: passo 29, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement, Unfasten the LCD screen: passo 29, imagem 2 %32
      • Use a Phillips #00 screwdriver to remove the four 4.2 mm screws securing the LCD screen.
      Pergunte ao FixBot
      Comentar
    3. iPad 9  LTE Button Control Cable Replacement, Separate the LCD's adhesive: passo 30, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement, Separate the LCD's adhesive: passo 30, imagem 2 %32
      • The LCD is lightly adhered to the frame.
      • Insert a spudger between the frame and the top-right portion of the LCD.
      • Pry slowly with the spudger to separate the adhesive.
      Pergunte ao FixBot
      Comentar
    4. iPad 9  LTE Button Control Cable Replacement: passo 31, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement: passo 31, imagem 2 %32
      • Repeat the previous step for the top-left portion of the LCD.
      Pergunte ao FixBot
      Comentar
    5. iPad 9  LTE Button Control Cable Replacement, Reposition the LCD screen: passo 32, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement, Reposition the LCD screen: passo 32, imagem 2 %32 iPad 9  LTE Button Control Cable Replacement, Reposition the LCD screen: passo 32, imagem 3 %32
      • Don't attempt to fully remove the LCD during this step, as it's still connected by a flex cable.
      • Use the flat end of a spudger to pry the LCD out of its recess just enough to grab it with your fingers.
      • Flip the LCD like a page in a book, lifting near the camera and turning it over the home button end of the frame.
      • Lay the LCD on a clean, soft, lint-free surface to allow access to the display cables.
      Pergunte ao FixBot
      Comentar
    6. iPad 9  LTE Button Control Cable Replacement, Disconnect the battery: passo 33, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement, Disconnect the battery: passo 33, imagem 2 %32
      • Use a Phillips screwdriver to remove the 2.3 mm-long screw securing the battery connector to the logic board.
      Pergunte ao FixBot
      Comentar
    7. iPad 9  LTE Button Control Cable Replacement, Battery connector information: passo 34, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement, Battery connector information: passo 34, imagem 2 %32 iPad 9  LTE Button Control Cable Replacement, Battery connector information: passo 34, imagem 3 %32
      • These photos show what the battery connector looks like underneath the logic board. Use these photos as a reference while you safely disconnect the battery.
      • Notice that the battery connector has cantilever springs on the logic board that press against the battery contact pads. Since both the logic board and battery are glued down, you'll need to slide something thin and flexible between the contact points to disconnect the battery.
      Pergunte ao FixBot
      Comentar
    8. iPad 9  LTE Button Control Cable Replacement, Disconnect the battery: passo 35, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement, Disconnect the battery: passo 35, imagem 2 %32 iPad 9  LTE Button Control Cable Replacement, Disconnect the battery: passo 35, imagem 3 %32
      • Be careful when you isolate the battery using a battery blocker. The battery contacts are easily bent or broken, resulting in irreversible damage.
      • Ensure that the iFixit logo on the battery blocker is facing up.
      • Slide the battery blocker underneath the logic board's battery connector at a 35 degree angle.
      • Don't push the battery blocker underneath the connector with excessive force. If you're having trouble fitting the battery blocker underneath the logic board, you can try using a playing card to disconnect the battery instead.
      • The battery blocker or playing card ideally should slide under the logic board without encountering any blockages. After insertion, it should rest at about a 15 degree angle.
      • Leave the battery blocker in place as you work.
      Pergunte ao FixBot
      Comentar
    9. iPad 9  LTE Button Control Cable Replacement, Unfasten the display cable bracket: passo 36, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement, Unfasten the display cable bracket: passo 36, imagem 2 %32
      • Use a Phillips screwdriver to remove the three 1.4 mm-long screws securing the display cable bracket.
      Pergunte ao FixBot
      Comentar
    10. iPad 9  LTE Button Control Cable Replacement, Remove the display cable bracket: passo 37, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement, Remove the display cable bracket: passo 37, imagem 2 %32
      • Remove the display cable bracket.
      Pergunte ao FixBot
      Comentar
    11. iPad 9  LTE Button Control Cable Replacement, Disconnect the LCD: passo 38, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement, Disconnect the LCD: passo 38, imagem 2 %32
      • Use the flat end of a spudger to pry up and disconnect the LCD cable press connector.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Pergunte ao FixBot
      Comentar
    12. iPad 9  LTE Button Control Cable Replacement, Remove the LCD: passo 39, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement, Remove the LCD: passo 39, imagem 2 %32
      • Remove the LCD completely and rest it face down on a clean, soft, lint-free surface.
      Pergunte ao FixBot
      Comentar
    1. iPad 9  LTE Button Control Cable Replacement, Disconnect the home button: passo 40, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement, Disconnect the home button: passo 40, imagem 2 %32
      • Use a pair of tweezers to peel off the tape covering the home button cable ZIF connector.
      Pergunte ao FixBot
      Comentar
    2. iPad 9  LTE Button Control Cable Replacement: passo 41, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement: passo 41, imagem 2 %32
      • Use a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the home button cable ZIF connector.
      Pergunte ao FixBot
      Comentar
    3. iPad 9  LTE Button Control Cable Replacement: passo 42, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement: passo 42, imagem 2 %32
      • Use a pair of tweezers to pull the home button ribbon cable straight out of the ZIF connector.
      Pergunte ao FixBot
      Comentar
    4. iPad 9  LTE Button Control Cable Replacement, Disconnect the display cables: passo 43, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement, Disconnect the display cables: passo 43, imagem 2 %32 iPad 9  LTE Button Control Cable Replacement, Disconnect the display cables: passo 43, imagem 3 %32
      • Use the flat end of a spudger to pry up and disconnect the two digitizer cable press connectors.
      • To avoid damaging your iPad, pry only on the connectors themselves, not on the socket on the logic board.
      Pergunte ao FixBot
      Comentar
    5. iPad 9  LTE Button Control Cable Replacement, Remove the buffer block: passo 44, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement, Remove the buffer block: passo 44, imagem 2 %32 iPad 9  LTE Button Control Cable Replacement, Remove the buffer block: passo 44, imagem 3 %32
      • Use the flat end of a spudger to pry up the buffer block near the bottom-right corner of the iPad.
      • Take care not to puncture or tear the home button ribbon cable.
      • Remove the buffer block.
      Pergunte ao FixBot
      Comentar
    6. iPad 9  LTE Button Control Cable Replacement: passo 45, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement: passo 45, imagem 2 %32 iPad 9  LTE Button Control Cable Replacement: passo 45, imagem 3 %32
      • The home button cable is secured with some light adhesive.
      • Use a pair of tweezers to peel the home button cable away from the frame.
      Pergunte ao FixBot
      Comentar
    7. iPad 9  LTE Button Control Cable Replacement, Remove the front panel assembly: passo 46, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement, Remove the front panel assembly: passo 46, imagem 2 %32 iPad 9  LTE Button Control Cable Replacement, Remove the front panel assembly: passo 46, imagem 3 %32
      Polyimide Tape
      $9.95
      • Remove the front panel assembly.
      • Use an opening pick to cut away any residual adhesive that may still be connecting the front panel assembly to the frame.
      • If you experience "ghost" or "phantom" touch input issues with your new display, this can be resolved by adding a layer of very thin insulating tape, such as Kapton (polyimide) tape, to the highlighted areas on the back of the panel. iFixit replacement digitizers come with the proper insulation and should not require the addition of any tape.
      • Without the proper insulation, these areas of the digitizer can ground out against other components, causing touch input malfunction.
      • The insulation is not visible to the naked eye and is different from the foam dust barrier strips found on many iPads.
      • During reassembly, before installing a display, remove any remaining adhesive from the iPad, and clean the glued areas with high concentration isopropyl alcohol (90% or greater) and a lint-free cloth. This helps prep the iPad for fresh adhesive and ensures that it will bond properly.
      • Test your iPad's functions and install pre-cut adhesive strips to the back of the display using our display adhesive application guide before sealing it up.
      Pergunte ao FixBot
      Comentar
    1. iPad 9  LTE Button Control Cable Replacement, Remove the upper bracket tape: passo 47, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement, Remove the upper bracket tape: passo 47, imagem 2 %32
      • Carefully peel the LCD buffer tape from the upper component bracket.
      Pergunte ao FixBot
      Comentar
    2. iPad 9  LTE Button Control Cable Replacement, Unfasten the upper component bracket: passo 48, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement, Unfasten the upper component bracket: passo 48, imagem 2 %32
      • Use a Phillips #00 screwdriver to remove the five screws securing the the upper component bracket:
      • Three 1.4 mm-long screws
      • Two 1.9 mm-long screws
      Pergunte ao FixBot
      Comentar
    3. iPad 9  LTE Button Control Cable Replacement, Remove the upper component bracket: passo 49, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement, Remove the upper component bracket: passo 49, imagem 2 %32
      • Use the pointed end of a spudger to lift up the upper component bracket until you can grip it with your fingers.
      Pergunte ao FixBot
      Comentar
    4. iPad 9  LTE Button Control Cable Replacement: passo 50, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement: passo 50, imagem 2 %32 iPad 9  LTE Button Control Cable Replacement: passo 50, imagem 3 %32
      • Use your fingers to peel the upper component bracket away from the tape.
      • Remove the upper component bracket.
      Pergunte ao FixBot
      Comentar
    1. iPad 9  LTE Button Control Cable Replacement, Disconnect the rear camera: passo 51, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement, Disconnect the rear camera: passo 51, imagem 2 %32
      • Use the flat end of a spudger to pry up and disconnect the rear camera press connector.
      Pergunte ao FixBot
      Comentar
    2. iPad 9  LTE Button Control Cable Replacement, Heat the rear camera: passo 52, imagem 1 %32
      • Heat an iOpener and apply it to the rear camera for thirty seconds.
      Pergunte ao FixBot
      Comentar
    3. iPad 9  LTE Button Control Cable Replacement, Remove the rear camera: passo 53, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement, Remove the rear camera: passo 53, imagem 2 %32 iPad 9  LTE Button Control Cable Replacement, Remove the rear camera: passo 53, imagem 3 %32
      • Use a spudger to pry the rear camera out of the frame.
      • Use tweezers, or your fingers, to remove the rear camera.
      Pergunte ao FixBot
      Comentar
    1. iPad 9  LTE Button Control Cable Replacement, Disconnect the right ambient light sensor: passo 54, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement, Disconnect the right ambient light sensor: passo 54, imagem 2 %32
      • The right ambient light sensor is lightly adhered to the frame.
      • Use tweezers, or your fingers, to remove the sensor.
      Pergunte ao FixBot
      Comentar
    2. iPad 9  LTE Button Control Cable Replacement, Reposition the right ambient light sensor: passo 55, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement, Reposition the right ambient light sensor: passo 55, imagem 2 %32
      • Peel the right ambient light sensor towards the right edge of the device, enough to access the screw behind it.
      Pergunte ao FixBot
      Comentar
    3. iPad 9  LTE Button Control Cable Replacement, Unfasten the power button bracket: passo 56, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement, Unfasten the power button bracket: passo 56, imagem 2 %32
      • Use a Phillips screwdriver to remove the two 2.3 mm-long screws securing the lock button bracket.
      Pergunte ao FixBot
      Comentar
    4. iPad 9  LTE Button Control Cable Replacement, Reposition the button control cable: passo 57, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement, Reposition the button control cable: passo 57, imagem 2 %32
      • Use your fingers to pull the power button bracket out of its recess.
      Pergunte ao FixBot
      Comentar
    5. iPad 9  LTE Button Control Cable Replacement: passo 58, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement: passo 58, imagem 2 %32 iPad 9  LTE Button Control Cable Replacement: passo 58, imagem 3 %32
      • The button control cable is lightly adhered to the side of the volume button bracket.
      • Peel the button control cable away from the volume button bracket.
      Pergunte ao FixBot
      Comentar
    6. iPad 9  LTE Button Control Cable Replacement, Unfasten the volume button bracket: passo 59, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement, Unfasten the volume button bracket: passo 59, imagem 2 %32
      • Use a Phillips screwdriver to remove the two 2.2 mm-long screws securing the volume button bracket to the rear case.
      Pergunte ao FixBot
      Comentar
    7. iPad 9  LTE Button Control Cable Replacement, Remove the volume button bracket: passo 60, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement, Remove the volume button bracket: passo 60, imagem 2 %32 iPad 9  LTE Button Control Cable Replacement, Remove the volume button bracket: passo 60, imagem 3 %32
      • Use tweezers, or your fingers, to pull the volume button bracket away from the device's edge.
      • Remove the volume button bracket.
      Pergunte ao FixBot
      Comentar
    8. iPad 9  LTE Button Control Cable Replacement, Disconnect the button control cable: passo 61, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement, Disconnect the button control cable: passo 61, imagem 2 %32
      • Peel off any tape covering the button control cable ZIF connector.
      Pergunte ao FixBot
      Comentar
    9. iPad 9  LTE Button Control Cable Replacement: passo 62, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement: passo 62, imagem 2 %32
      • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the button control cable's ZIF connector.
      Pergunte ao FixBot
      Comentar
    10. iPad 9  LTE Button Control Cable Replacement: passo 63, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement: passo 63, imagem 2 %32
      • Use a pair of tweezers to carefully pull the button control cable straight out of the ZIF connector.
      Pergunte ao FixBot
      Comentar
    11. iPad 9  LTE Button Control Cable Replacement, Remove the button control cable: passo 64, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement, Remove the button control cable: passo 64, imagem 2 %32 iPad 9  LTE Button Control Cable Replacement, Remove the button control cable: passo 64, imagem 3 %32
      • Use the flat end of a spudger to push the volume buttons out of their slots in the rear case.
      Pergunte ao FixBot
      Comentar
    12. iPad 9  LTE Button Control Cable Replacement, Remove the button control cable: passo 65, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement, Remove the button control cable: passo 65, imagem 2 %32
      • Remove the button control cable.
      • The lock button will become loose once the button control cable is removed.
      • Upon reassembly, remember to set the power button back into the its slot.
      Pergunte ao FixBot
      Comentar
    13. iPad 9  LTE Button Control Cable Replacement, Loosen the adhesive: passo 66, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement, Loosen the adhesive: passo 66, imagem 2 %32
      • Heat an iOpener and apply it to the button control cable for thirty seconds.
      Pergunte ao FixBot
      Comentar
    14. iPad 9  LTE Button Control Cable Replacement, Remove the buttons: passo 67, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement, Remove the buttons: passo 67, imagem 2 %32 iPad 9  LTE Button Control Cable Replacement, Remove the buttons: passo 67, imagem 3 %32
      • Use a pair of tweezers to grip the upper volume button.
      • Insert an opening pick between the volume control cable and the upper volume button.
      • Peel the volume control cable off of the upper volume button.
      Pergunte ao FixBot
      Comentar
    15. iPad 9  LTE Button Control Cable Replacement: passo 68, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement: passo 68, imagem 2 %32 iPad 9  LTE Button Control Cable Replacement: passo 68, imagem 3 %32
      • Repeat the same process to peel the volume control cable off of the lower volume button.
      Pergunte ao FixBot
      Comentar
    16. iPad 9  LTE Button Control Cable Replacement, Remove the power button bracket: passo 69, imagem 1 %32 iPad 9  LTE Button Control Cable Replacement, Remove the power button bracket: passo 69, imagem 2 %32 iPad 9  LTE Button Control Cable Replacement, Remove the power button bracket: passo 69, imagem 3 %32
      Tesa 61395 Tape
      $8.95
      • Use a pair of tweezers to grip the power button bracket.
      • Insert a halberd spudger or opening pick between the power button bracket and the button control cable.
      • Peel the button control cable up and off of the pegs on the power button bracket.
      • Upon reassembly, apply Tesa tape to reattach the volume buttons and lock button bracket to the button control cable.
      Pergunte ao FixBot
      Comentar
    17. iPad 9  LTE Button Control Cable Replacement: passo 70, imagem 1 %32
      • Only the button control cable remains.
      Pergunte ao FixBot
      Comentar
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad 9 Answers community for help.
Alex Diaz-Kokaisl
Membro desde: 01/16/22
247.503 Reputação
Autoria de 1.203 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 78.608 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 38
Ao todo: 1,060
