Ir para o conteúdo principal
iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement
Andrew Optimus Goldheart
Andrew Optimus Goldheart e 7 outros colaboradores
Última atualização em January 23, 2019
1 - 3 horas
Muito difícil
Introdução
Ir para o passo 1
Use this guide to replace the speaker assembly.
O que você precisa
Peças
Ferramentas
Exibir mais…
  1. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement, iOpener Heating: passo 1, imagem 1 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement, iOpener Heating: passo 1, imagem 2 %32
    • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
    • Place the iOpener in the center of the microwave.
    • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
  2. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 2, imagem 1 %32
    • Heat the iOpener for thirty seconds.
    • Depending on the wattage of your microwave, more or less time may be required. The iOpener is sufficiently heated when it's barely too hot to touch.
    • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
    • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst. Do not attempt to heat over 100˚C (212˚F).
    • Never touch the iOpener if it appears swollen.
    • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
  3. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 3, imagem 1 %32
    • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
  4. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement, Alternate iOpener heating method: passo 4, imagem 1 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement, Alternate iOpener heating method: passo 4, imagem 2 %32
    • If you don't have a microwave, follow this step to heat your iOpener in boiling water.
    • Fill a pot or pan with enough water to fully submerge an iOpener.
    • Heat the water to a boil. Turn off the heat.
    • Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
    • Use tongs to extract the heated iOpener from the hot water.
    • Thoroughly dry the iOpener with a towel.
    • The iOpener will be very hot, so be careful to hold it only by the end tabs.
    • Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
  5. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement, Front Panel: passo 5, imagem 1 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement, Front Panel: passo 5, imagem 2 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement, Front Panel: passo 5, imagem 3 %32
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
  6. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 6, imagem 1 %32
    Ferramenta utilizada neste passo:
    Safety Glasses
    $3.19
    • Again, as you may find yourself working with broken glass during this procedure, we strongly recommend wearing safety glasses for protection from flying shards.
    • Lay the iOpener flat on the right edge of the iPad, smoothing it out so that there is good contact between the surface of the iPad and the iOpener.
    • Let the bag sit on the iPad for approximately 90 seconds before attempting to open the front panel.
  7. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 7, imagem 1 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 7, imagem 2 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 7, imagem 3 %32
    • There is a small gap in the iPad's adhesive ring in the upper right corner of the iPad, approximately 2.0 inches (~5 cm) from the top of the iPad. You are going to exploit this weakness.
    • Align the tool with the mute button. Insert the tip of a plastic opening tool into the gap between the front glass and the plastic bezel. Just insert the very tip of the opening tool, just enough to widen the crack.
    • It may require some force to get the wedged tip of the opening tool between the glass and plastic. Work patiently and carefully, wiggling the plastic opening tool back and forth as necessary.
  8. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 8, imagem 1 %32
    • Make sure you place the tool in the proper spot—between the plastic display bezel and the front panel glass.
  9. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 9, imagem 1 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 9, imagem 2 %32
    • Keeping the tip of the plastic opening tool wedged between the front glass and plastic bezel, slide a plastic opening pick in the gap, right next to the plastic opening tool.
  10. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 10, imagem 1 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 10, imagem 2 %32
    • Remove the plastic opening tool from the iPad, and push the opening pick further underneath the front glass to a depth of ~0.5 inches.
  11. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 11, imagem 1 %32
    • While you work on releasing the adhesive on the right side of the iPad, reheat the iOpener, and replace it on the bottom edge of the iPad.
  12. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 12, imagem 1 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 12, imagem 2 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 12, imagem 3 %32
    • While the bottom edge is being heated by the iOpener, begin releasing the adhesive from the right edge of the iPad.
    • Slide the opening pick down along the edge of the iPad, releasing the adhesive as you go.
    • The adhesive is very strong, and some serious force may be required. Work carefully.
    • If you can see the tip of the opening pick underneath the front glass, pull the pick out just a little bit. While using the opening pick this deep won't damage anything, it may get adhesive residue all over the LCD.
  13. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 13, imagem 1 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 13, imagem 2 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 13, imagem 3 %32
    • It may be necessary to move the heated iOpener back onto the right edge of the iPad as you release the adhesive. This depends on how long the iPad has been able to cool while you were working on it.
    • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad, continuing to release the adhesive.
  14. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 14, imagem 1 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 14, imagem 2 %32
    • Before removing the first opening pick from the bottom corner of the iPad, insert a second pick under the right edge of the front glass to keep the adhesive from re-adhering.
    • Re-heat the iOpener, and move it to the top edge of the iPad.
  15. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 15, imagem 1 %32
    • The next few steps require extreme caution.
    • The Wi-Fi antenna is attached to the bottom right edge of the rear case of the iPad via screws and a cable. Because of the orientation of the Wi-Fi antenna, it is imperative to proceed with caution otherwise irreversible damage to the Wi-Fi antenna may result.
    • You will have to release the adhesive securing the antenna to the front panel without damaging the delicate parts attaching the antenna to the bottom of the iPad. Follow the next steps carefully.
  16. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 16, imagem 1 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 16, imagem 2 %32
    • Slide the opening pick around the bottom right corner of the iPad, releasing the adhesive there.
    • Do not slide the pick further than the bottom right corner. You may damage the Wi-Fi antenna by doing so.
  17. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 17, imagem 1 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 17, imagem 2 %32
    • This step requires you to move the opening pick along the bottom right edge of the front panel. The Wi-Fi antenna is very close to the corner and is easily severed if the adhesive is released improperly.
    • Do not completely remove the pick from under the front glass, but pull it out just a little bit so that ~1/8" (3 mm) of the tip is still under the front glass.
    • Slide the tip of the opening pick along the bottom edge of the iPad, releasing the adhesive over the Wi-Fi antenna.
  18. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 18, imagem 1 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 18, imagem 2 %32
    • Once you have moved past the Wi-FI antenna (approximately 3" (75 mm) from the right edge, or right next to the home button) re-insert the opening pick to its full depth.
    • Slide the pick to the right, releasing the adhesive securing the Wi-Fi antenna to the front glass.
    • The antenna is attached to the bottom of the iPad via screws and a cable. This step detaches the antenna from the front panel, ensuring that when you remove the panel, the antenna will not be damaged.
  19. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 19, imagem 1 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 19, imagem 2 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 19, imagem 3 %32
    • Continue releasing the adhesive along the bottom of the iPad, pulling the opening pick out far enough to go around the home button, and re-inserting it to a depth of 1/2 inch (10 mm) once the pick is past the home button.
    • If the adhesive has cooled too much along the bottom edge, reheat the iOpener to warm the adhesive where you are working.
    • Do not heat the iOpener more than a minute at a time, and always allow at least two minutes before reheating it.
  20. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 20, imagem 1 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 20, imagem 2 %32
    • Continue releasing the adhesive all the way along the bottom edge of the iPad.
    • On iPad 4 models, insert the pick to a maximum depth of 1/2 inch (10 mm) in this area, to avoid damaging the home button ribbon cable.
    • Leave the opening pick wedged underneath the front glass near the home button.
  21. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 21, imagem 1 %32
    • Reheat the iOpener in the microwave and set it on the left edge of the iPad to start warming the adhesive in that section.
  22. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 22, imagem 1 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 22, imagem 2 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 22, imagem 3 %32
    • Slide the opening pick along the top edge of the iPad, pulling it out slightly to go around the front-facing camera bracket.
    • The adhesive along this section is very thick, and a fair amount of force may be required. Work carefully and slowly, making sure to not slip and damage yourself or your iPad.
    • If the adhesive has cooled too much, replace the iOpener along the top edge and continue working. If the iOpener has cooled too much, reheat it.
    • If the opening pick is getting stuck in the adhesive, "roll" the pick as shown in step 9.
  23. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 23, imagem 1 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 23, imagem 2 %32
    • Continue releasing the adhesive along the top edge of the iPad, and slide the opening pick around the top left corner.
    • If the adhesive is warm enough, remove the iOpener from the iPad for convenience. However, if the adhesive is still quite sticky, re-heat the iOpener and lay it on the left edge while you work.
  24. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 24, imagem 1 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 24, imagem 2 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 24, imagem 3 %32
    • Slide the opening pick along the left edge of the iPad, releasing the adhesive as you go. The adhesive is thin here due to the digitizer along the whole left side. Make sure the pick is not too deep (max 1/2 inch) 10 mm to prevent damaging the digitizer.
    • The digitizer cable is located approximately 2" (50 mm) from the bottom of the iPad. Stop sliding the pick when you get ~2.25" (60 mm) from the bottom of the iPad.
  25. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 25, imagem 1 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 25, imagem 2 %32
    • Using the opening pick that is still underneath the bottom edge of the iPad, release the adhesive along the bottom left corner.
    • The bottom of the digitizer cable is only ~1" (25 mm) from the bottom of the iPad. Work carefully and slowly, making sure to not sever this cable.
  26. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 26, imagem 1 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 26, imagem 2 %32
    • Using one of the opening picks, pry up the bottom right corner of the iPad and grab it with your fingers.
    • Some of the adhesive along the perimeter of the iPad may have stuck back down again. If this is the case, slide a pick underneath the edge of the iPad where the front glass is still stuck and "cut" the adhesive.
  27. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 27, imagem 1 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 27, imagem 2 %32
    Microfiber Cleaning Cloths
    $3.99
    • Holding the iPad by the top and bottom right corners, rotate the front glass away from the iPad.
    • Be careful of any adhesive that may still be attached, and use an opening pick to cut any adhesive that may still be holding the front panel down.
    • During reassembly use a microfiber cloth and compressed air to clean any dust or fingerprints off the LCD before reinstalling the glass.
  28. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement, LCD: passo 28, imagem 1 %32
    • Remove the four 2.0 mm Phillips screws securing the LCD to the rear case.
  29. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 29, imagem 1 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 29, imagem 2 %32
    • The front panel ribbon cables are connected beneath the LCD. To access them, you'll need to temporarily flip the LCD over and out of the way.
    • Be very careful when moving the LCD, and do not attempt to remove it from the iPad—its display data cable will remain connected while it is rotated over.
    • Lift the LCD from its long edge closest to the volume buttons and gently flip it out of the rear case—like turning the page in a book.
    • Set the LCD face down on the front panel.
  30. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement, Front Panel Assembly: passo 30, imagem 1 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement, Front Panel Assembly: passo 30, imagem 2 %32
    • Use the edge of a plastic opening tool to carefully flip up the retaining flaps on the two digitizer ribbon cable ZIF sockets.
    • Be sure you are prying up on the hinged retaining flaps, not the sockets themselves.
    • The retaining flaps are highlighted in red in the second picture.
  31. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 31, imagem 1 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 31, imagem 2 %32
    • Use the edge of a plastic opening tool to peel the digitizer cable off the shields on the logic board.
    • Carefully pull the digitizer cable off the adhesive securing it to the side of the rear case.
  32. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 32, imagem 1 %32
    • Pull the digitizer ribbon cable straight out of its two sockets on the logic board.
  33. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 33, imagem 1 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 33, imagem 2 %32
    • In order to remove the front panel assembly, the ribbon cable needs to slide out between the case and the LCD. You'll need to move the LCD to make some room.
    • Be very careful when moving the LCD, and do not attempt to remove it from the iPad—its cable will remain connected while it is rotated over.
    • Lift the LCD from its long edge farthest from the digitizer cable and gently flip it toward the rear case—like closing a book.
    • While holding the LCD up, gently slide the front panel away from the iPad. Be careful not to snag the digitizer cable on the rear case or LCD.
    • Set the LCD back into the body for safekeeping.
  34. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement, LCD Assembly: passo 34, imagem 1 %32
    • In order to work on the iPad's innards, we need to flip the LCD back out of the case.
    • Set the LCD face down on a clean surface. You may want to rest it on a soft cloth to prevent scratches.
  35. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement, Logic Board: passo 35, imagem 1 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement, Logic Board: passo 35, imagem 2 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement, Logic Board: passo 35, imagem 3 %32
    • Use a plastic opening tool to lift the display data cable lock upwards.
    • Pull the display data cable out of its socket.
    • Be careful not pull the connector upward as you disconnect it from its socket.
  36. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 36, imagem 1 %32
    • Remove the LCD assembly from the rear panel assembly.
  37. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 37, imagem 1 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 37, imagem 2 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 37, imagem 3 %32
    • If present, remove the piece of tape on the dock connector cable with a plastic opening tool.
    • Use the edge of a plastic opening tool to carefully pry the dock connector cable's connector up from its socket on the logic board.
    • Peel the dock connector ribbon cable off the rear panel.
  38. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 38, imagem 1 %32
    • Pry the speaker cable connector straight up from its socket on the logic board.
    • Be careful to pry only the connector, not the socket on the logic board, or you may destroy the socket.
  39. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 39, imagem 1 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 39, imagem 2 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 39, imagem 3 %32
    • Remove the following screws:
    • Two 2.1 mm Phillips screws securing one of two metal brackets to the rear case.
    • One 2.6 mm Phillips screw securing the logic board to the rear case.
    • Remove the metal bracket from the rear case.
  40. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 40, imagem 1 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 40, imagem 2 %32
    • If present, use tweezers to remove the piece of tape covering the end of the headphone jack/control board cable.
  41. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 41, imagem 1 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 41, imagem 2 %32
    • Use the flat end of a spudger to flip up the retaining flap on the headphone jack/control board cable ZIF socket.
    • Be sure you are prying upward on the hinged retaining flap, not the socket itself.
  42. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 42, imagem 1 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 42, imagem 2 %32
    • Slide the tip of a spudger underneath the headphone jack/control board ribbon cable to disconnect it.
  43. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 43, imagem 1 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 43, imagem 2 %32
    • Remove the two 2.1 mm Phillips screws securing the second metal bracket to the rear case near the digitizer cable socket.
  44. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 44, imagem 1 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 44, imagem 2 %32
    • Use the edge of a plastic opening tool to gently pry the logic board up from the adhesive securing it to the rear case.
  45. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 45, imagem 1 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 45, imagem 2 %32
    • Lift the logic board out from the rear case and flip it over toward the battery.
    • Do not try to completely remove it just yet. There is still an antenna cable attached to it.
  46. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 46, imagem 1 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 46, imagem 2 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 46, imagem 3 %32
    • Use the tip of a spudger to pry the Wi-Fi antenna connector up from its socket on the logic board.
    • Remove the logic board from the case.
  47. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement, Battery: passo 47, imagem 1 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement, Battery: passo 47, imagem 2 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement, Battery: passo 47, imagem 3 %32
    • Reheat the iOpener in the microwave for one minute.
    • Remember to be careful not to overheat the iOpener during the repair procedure. Wait at least two minutes before reheating the iOpener, and never microwave it for more than one minute.
    • Place the heated iOpener on the back of the iPad just right of center (the side opposite the rear facing camera). Let it sit there for 90 seconds to soften the battery adhesive.
    • Move the iOpener to the center of the back of the iPad and let the iOpener sit for another 90 seconds.
    • If the iOpener cools significantly between sittings, reheat it for another minute.
    • Move the iOpener to the left edge (the side with the rear facing camera) of the back of the iPad and let the iOpener sit for another 90 seconds.
  48. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 48, imagem 1 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 48, imagem 2 %32
    Plastic Cards
    $2.99
    • Throughout the following procedure, you'll be sliding thin plastic cards between the battery and rear case of the iPad, to separate the adhesive securing the battery in place. Be careful to keep the cards as flat as possible to avoid bending the battery, which may damage it and cause it to release dangerous chemicals.
    • Flip the iPad back over and insert a plastic card between the bottom battery cell and the rear case.
    • If you encounter significant resistance, re-heat the iOpener and repeat the previous step to give the adhesive more time to soften.
  49. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 49, imagem 1 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 49, imagem 2 %32
    • Starting with the battery cell closest to the dock connector, run a plastic opening tool underneath the edge of the battery closest to the logic board void to make enough room to insert a plastic card.
  50. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 50, imagem 1 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 50, imagem 2 %32
    • Insert the card at the case side corner and slide inward to separate more adhesive.
  51. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 51, imagem 1 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 51, imagem 2 %32
    • Work the card around the corner and insert along the case-side of the cell.
    • Insert the card at as shallow an angle as you can manage to avoid bending the battery.
  52. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 52, imagem 1 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 52, imagem 2 %32
    • Insert the card at the bottom corner (closest to the headphone jack) to free this side of the battery cell.
  53. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 53, imagem 1 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 53, imagem 2 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 53, imagem 3 %32
    • Slide the card along the side of the cell to detach any remaining adhesive.
  54. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 54, imagem 1 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 54, imagem 2 %32
    • Gently pry the end of the battery cell away from the case.
  55. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 55, imagem 1 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 55, imagem 2 %32
    • Gently pry the corner of the battery off of the case to begin freeing the final side of the dock side cell.
  56. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 56, imagem 1 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 56, imagem 2 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 56, imagem 3 %32
    • Gently pry up the remaining corner of the cell. Avoid bending the cable connecting the battery cells.
    • Leave this card in place to prevent the adhesive from resetting while you loosen the other battery cells.
  57. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 57, imagem 1 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 57, imagem 2 %32
    • On the battery cell nearest the headphone jack, run a second plastic card underneath the edge adjacent to the logic board void.
  58. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 58, imagem 1 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 58, imagem 2 %32
    • Slide the card in to free the corner of the cell from adhesive.
  59. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 59, imagem 1 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 59, imagem 2 %32
    • Pry gently to free the corner of the cell from the case.
  60. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 60, imagem 1 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 60, imagem 2 %32
    • Slide the card under the opposite corner to detach yet more adhesive.
  61. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 61, imagem 1 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 61, imagem 2 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 61, imagem 3 %32
    • Give a final swipe to get the last of that stubborn adhesive.
  62. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 62, imagem 1 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 62, imagem 2 %32
    • A final pry, and the card can be left in place to keep the battery propped away from the adhesive.
  63. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 63, imagem 1 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 63, imagem 2 %32
    • Time to tackle that center battery cell. By now, the adhesive may have cooled a bit; another application of the iOpener might be helpful at this point.
    • Slide the card under the center cell near the cable.
    • Insert the card near the far end of the battery.
  64. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 64, imagem 1 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 64, imagem 2 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 64, imagem 3 %32
    • Gently pry the bottom of the cell up from the case.
    • Pry the dock side corner of the cell up from the adhesive.
    • Pry again near the cable to loosen the cell further.
  65. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 65, imagem 1 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 65, imagem 2 %32
    • Slide a corner of the card under the top of the cell (the side adjacent to the logic board void).
    • Use the screw post as a pivot point to detach the last of the adhesive under the battery conector board.
  66. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 66, imagem 1 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 66, imagem 2 %32
    • Insert the cards at the junctures between batteries.
    • Pry upwards to free the battery connector board from the screw post and the battery assembly from the case.
    • Do not excessively bend the battery connector board. Be especially careful when prying up around the screw post on the aluminum rear case.
  67. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 67, imagem 1 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 67, imagem 2 %32
    • Lift and gently remove the battery assembly from the case.
    • You may need to reach in between the battery and the rear case with a plastic card to cut any remaining adhesive.
  68. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement, Speaker Assembly: passo 68, imagem 1 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement, Speaker Assembly: passo 68, imagem 2 %32
    • Carefully peel up the dock connector and speaker cables to reveal the Wi-Fi antenna cable.
    • Peel the Wi-Fi antenna cable off the rear panel.
  69. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 69, imagem 1 %32
    • Remove the following four screws:
    • Two 2.0 mm Phillips screws
    • Two 1.7 mm Phillips screws
  70. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 70, imagem 1 %32
    • Peel the Wi-Fi antenna off the speaker enclosure and remove it from the iPad 2.
  71. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 71, imagem 1 %32
    • Peel the dock connector cable off the speaker cable.
    • Be sure the small rings of EMI foam remain stuck to the dock connector cable.
  72. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 72, imagem 1 %32
    • Use the edge of a plastic opening tool to peel up the edge of the large strip of tape securing the speaker assembly to the rear panel.
    • Use your fingers to peel the strip of tape off the speaker assembly.
  73. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 73, imagem 1 %32
    • Remove the following two screws:
    • One 3 mm Phillips screw
    • One 2.1 mm Phillips screw
  74. iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 74, imagem 1 %32 iPad 2 Wi-Fi EMC 2560 Speaker Assembly Replacement: passo 74, imagem 2 %32
    • Use the edge of a plastic opening tool to help push the speaker assembly out from under the right side of the rear panel.
    • Remove the speaker assembly from the iPad 2.
Conclusão
To reassemble your device, follow these directions in reverse and use our iPad 2 Wi-Fi EMC 2560 Front Panel Adhesive strips guide to reattach the front panel.
5 outras pessoas executaram este guia.
Membro desde: 10/17/09
508.871 Reputação
Autoria de 407 guias
Equipe
iFixit Membro de iFixit
Staff
118 Membros
Autoria de 19.530 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Ao todo: 3,675
