Introdução
We couldn’t squeeze every last ounce of chip ID into our iMac M1 24” teardown. So if you couldn’t get enough of that sweet silicon, here is a much more thorough look into the chips found on the logic board, interconnect board, and display board.
Back side of the logic board:
Apple APL1102/339S00817 64-bit M1 8-core SoC (system on a chip).
SK Hynix H9HCNNNCRMMVGR-NEH 8 GB (2 x 4 GB) LPDDR4 memory
Kioxia KICM225VE4779 128 GB NAND Flash
Murata 339S00763 Wi-Fi/Bluetooth module
Apple APL1096/343S00474 power management IC
Apple APL1097/343S00475 power management IC
Richtek RT4541GQV power management IC
Back side of the logic board, continued:
Texas Instruments INA210 bi-directional current sense amplifier
Texas Instruments INA214 bi-directional current sense amplifier
Texas Instruments TPS62137 DC-DC converter
Dialog Semiconductor (formerly Silego) SLG59M301V 4-amp load switch
Texas Instruments SN74AVC4T234 4-bit bus transceiver
Front side of the logic board:
Broadcom BCM57762 ethernet controller
Infineon (formerly Cypress Semiconductor) CYPDC1185B2-32LQXQ USB-C cable controller
Cirrus Logic CS42L83A audio codec
Analog Devices SSM3515B 31-watt class-D audio amplifier
Analog Devices (formerly Linear Technology) LTC3890-2 two-phase synchronous step-down converter
Texas Instruments TPS259827ON 15-amp eFuse with load current monitoring and transient fault management
Front side of logic board, continued:
Macronix MX25U6472F 64 MB serial NOR flash memory
Texas Instruments OPA333 single zero-drift CMOS operational amplifier
Temperature sensor (likely)
Nexperia (formerly NXP Semiconductor) 74AVC2T45 2-bit dual-supply voltage level translator/transceiver
Texas Instruments SN74AHC1G32 single 2-input OR gate
NXP Semiconductor SN210V NFC controller with secure element
Interconnect board:
ASMedia ASM3142 PCIe-to-USB 3.1 Gen 2 controller
Texas Instruments CD3218B12 USB-C port/power delivery controller
Intel JHL8040R Thunderbolt 4 retimer
ASMedia ASM1543 10 Gbps 4:2 mux switch with USB 3.1 type-C compatibility
Texas Instruments TMP464 five-channel temperature sensor
Interconnect board, continued:
Winbond W25Q80DVUXIE 8 MB serial NOR flash memory
Texas Instruments INA231BIYFD 16-bit current/voltage/power monitor
Texas Instruments TMUX1108 1-channel analog multiplexer (likely)
Texas Instruments TLV75533P 500 mA LDO regulator
Maxim Integrated DC-DC converter
Nexperia (formerly NXP Semiconductor) 74AUP1G09 single AND gate
Nexperia (formerly NXP Semiconductor) LSF0101 1-bit bidirectional multi-voltage level translator
Texas Instruments SN74AXC1T45 dual-supply bus transceiver
Texas Instruments SN74AUP1G17 Schmitt trigger (likely)
Left side of the display board:
Parade Technologies DP855A DisplayPort timing controller
Silicon Works SW50024 LCD level shifter
Winbond W25Q40EWUXIE 4 MB serial NOR flash memory
Texas Instruments TMP468 9-channel temperature sensor
Dialog Semiconductor (formerly Silego) SLG46826 mixed signal array
Analog Devices (formerly Linear Technology) LTC3115-1 2-amp synchronous buck converter
Texas Instruments TPS62140 2-amp step-down converter
Right side of the display board:
Texas Instruments BUF18830 18-channel gamma-voltage generator
Richtek RT6811HGQV display power management
Texas Instruments TPS259571 eFuse with over-voltage protection
Texas Instruments TPS26621 800 mA eFuse with I/O reverse polarity protection
Texas Instruments 2N7001T 1-bit dual-supply buffered voltage signal converter
Texas Instruments TLV76701 1-amp LDO Regulator
Texas Instruments SN74LVC1G04 single inverter
Left and right side of the display board, continued:
Texas Instruments OPA2810 dual rail-to-rail I/O operational amplifier
ON Semiconductor analog switch
Dialog Semiconductor load switch (likely)
Texas Instruments microcontroller (likely)
Texas Instruments regulator (likely)
Display drivers
A partial list of chips on the power supply board:
NXP Semiconductor TEA19161T digital power supply controller
NXP Semiconductor TEA19162T power factor correction controller
NXP Semiconductor TEA2095TE dual synchronous rectifier switching controller
Um comentário
76MiB of flash across the boards on this machine. Apple really does like large amounts of ROM, don’t they?
