iMac G5 20" Model A1076 RAM Replacement
Introdução
Ir para o passo 1Instantly increase the speed of your iMac by upgrading the RAM.
O que você precisa
Peças
Ferramentas
Exibir mais…
Lay the iMac display-side down on a flat surface (putting a cloth under the screen to protect it from bumps).
Loosen the three Phillips screws securing the rear panel to the iMac.
Rotate each of the two RAM retaining arms away from the RAM chip.
Pull the RAM chip straight away from its socket.
31 outras pessoas executaram este guia.
2Comentários do guia
como se llama la cajita blanca que esta debajo de las memorias y que funcion tiene?
Easy as pie, instructions were right to the point, thank you.
Some models (with light sensor) have only the two outboard screws.
Robert Huber - Responder
