Ir para o conteúdo principal
iBook G3 Clamshell Modem Replacement
iRobot
iRobot e 3 outros colaboradores
Última atualização em 30 de jul de 2025
Nenhuma estimativa
Moderado
Introdução
Ir para o passo 1
56k internal modem, standard on all models.
O que você precisa
Peças
Ferramentas
Exibir mais…
  1. iBook G3 Clamshell Modem Replacement, Battery: passo 1, imagem 1 %32
    • Use a coin to turn both battery locking screws 90 degrees to the left.
    • Remove the battery cover.
    • Remove the battery from the computer by pulling up on the plastic tab.
  2. iBook G3 Clamshell Modem Replacement, Airport Card: passo 2, imagem 1 %32
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free. Note that the keyboard ribbon is still attached to the logic board, so you cannot completely remove the keyboard yet.
    • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw (between F4 and F5 key) 180 degrees in either direction and try again.
    • Rotate the keyboard away from the screen and rest it face-down on the trackpad area.
  3. iBook G3 Clamshell Modem Replacement: passo 3, imagem 1 %32
    • If your computer does not have an airport card, you can skip the next two steps.
    • Grasp the clear plastic tab on the airport card and pull up and toward the display.
    Note to those who want to install an airport card to a laptop here that doesn't have a card. The proper orientation is with the bar code facing up, and the "Airport" artwork and logo facing down. There are small slots on the bottom of the card that fit into pins below the trackpad. You will know it is properly slotted because the top of the card will touch the handles of the RAM shield.
    The proper orientation of the antenna is that it is plugged in from the right side of the top of the airport card, with the cable winding up from the right to the left.
    Marissa Stardance - Responder
  4. iBook G3 Clamshell Modem Replacement: passo 4, imagem 1 %32
    • Hold the airport card in one hand and use your other hand to remove the antenna cable.
  5. iBook G3 Clamshell Modem Replacement, Keyboard: passo 5, imagem 1 %32
    • Remove the two Phillips screws that secure the RAM shield.
  6. iBook G3 Clamshell Modem Replacement: passo 6, imagem 1 %32
    • Grasp the wire metal bracket on top of the RAM shield and pull upward to remove the shield.
  7. iBook G3 Clamshell Modem Replacement: passo 7, imagem 1 %32
    • Pull up the keyboard connector cable by its clear plastic loop.
  8. iBook G3 Clamshell Modem Replacement, Upper Case: passo 8, imagem 1 %32
    • Use a straightened paperclip to manually eject the CD-ROM tray.
  9. iBook G3 Clamshell Modem Replacement: passo 9, imagem 1 %32
    • Turn the computer over so that the bottom is facing up.
    • Remove the following Torx screws:
    • Four short T8 Torx near the battery compartment.
    • Two long T8 Torx near the hinges.
  10. iBook G3 Clamshell Modem Replacement: passo 10, imagem 1 %32
    • Pull the CD-ROM drive tray partly out.
    • Remove the silver Phillips screw from the plastic casing.
    Note to people whose Clamshell ibook doesn't have the CD tray cover any more -- you do not have to open the drive for this part because when you flip the machine to remove the screw, it will be visible. The cover normally obscures this part.
  11. iBook G3 Clamshell Modem Replacement: passo 11, imagem 1 %32
    • Turn the computer over.
    • Remove the three Phillips screws.
    Please note: these screws can (and may!) strip easily, so take extra care in removing them!
    LambdaCalculus - Responder
  12. iBook G3 Clamshell Modem Replacement: passo 12, imagem 1 %32
    • This is a diagram of the trackpad ribbon clamp connector you will disconnect in the next step.
    • 1) With your fingernails, grasp the locking bar on either side and pull up a small amount (about 1/16" or 2 mm).
    • 2) After disengaging the locking bar, slide the cable out of the connector.
    In part 1, you can use a small flat-blade screwdriver to lift the locking bar. This will not put pressure on the cable itself. Each end of the locking bar will click when it has been lifted sufficiently.
    Don Solomon - Responder
  13. iBook G3 Clamshell Modem Replacement: passo 13, imagem 1 %32
    • Loosen the trackpad clamp by pulling the top piece up slightly, freeing the trackpad ribbon.
    • Slide the orange trackpad ribbon out of the clamp.
    Before going to the next step, remove 4 T8 screws from bottom of case.
    gestler - Responder
  14. iBook G3 Clamshell Modem Replacement: passo 14, imagem 1 %32
    • Do not lift the upper case too far without first disconnecting the audio cable.
    • Push out the rim of the lower case and pull up on the upper case, grasping it just to the left of the optical drive.
    • Repeat the above step on the upper left corner of the upper case, grasping the bottom left corner of the upper case.
  15. iBook G3 Clamshell Modem Replacement: passo 15, imagem 1 %32
    • Disconnect the audio cable.
  16. iBook G3 Clamshell Modem Replacement: passo 16, imagem 1 %32
    • Grasp the upper case on either side of the keyboard space and rotate up and away from the screen.
    • You may be thinking you're about to break your upper case. Not to worry - the tabs holding the upper and lower cases together are very strong. Simply apply even pressure and continue to rotate the upper case up and away from the screen until it comes free.
    When replacing the upper case, test the trackpad button to make sure it clicks before proceeding. If it does not operate properly, remove the upper case and reattach it.
    Once you free the back half, pull the the case forward, not up so much, or you’ll break the tabs on the sides by the optical drive on the right, and about the same place on the left.
    Rick - Responder
  17. iBook G3 Clamshell Modem Replacement, Modem: passo 17, imagem 1 %32
    • Remove the following Phillips screws:
    • Remove the longer Phillips screw from the middle-rear of the modem shield.
    • Remove the three identical Phillips screws, two on either side of the EMI fingers, and the remaining one on the right side of the modem shield.
    • Remove the larger Phillips screw that secures the EMI fingers to the modem board.
    • Remove the EMI fingers.
  18. iBook G3 Clamshell Modem Replacement: passo 18, imagem 1 %32
    • Peel the modem shield away from the metal framework below, working from the right front and moving to the left.
  19. iBook G3 Clamshell Modem Replacement: passo 19, imagem 1 %32
    • Remove the Phillips screw from the left side of the modem.
    • Pry up the right side of the modem.
  20. iBook G3 Clamshell Modem Replacement: passo 20, imagem 1 %32
    • Lift the modem partially out and disconnect the cable on the left side.
Conclusão
Uma outra pessoa concluiu este guia.
Documentos anexados
Gear Up For Future Repairs
Shop all
iRobot
Membro desde: 09/24/09
1 Reputação
Autoria de 636 guias
1Comentário do guia
is there a way to upgrade the modem so it works with modern internet feeds?
richardmmckay - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 12
Ao todo: 5,050
