Ir para o conteúdo principal
Vizio SmartCast Tablet Remote XR6M Micro-USB Port Replacement
tate campbell
tate campbell e 2 outros colaboradores
Última atualização em December 10, 2018
5 - 15 minutos
Moderado
Introdução
Ir para o passo 1
If the battery appears to be working, and the device charges normally when sitting on the charging stand, but does not charge when connected to a USB cable, you may need to replace the Micro-USB Port. Here we have included a step-by-step guide for the replacement of the Port.
O que você precisa
Ferramentas
  • Spudger
    Spudger
  • iFixit Opening Tool
    iFixit Opening Tool
  • T5 Torx Screwdriver
    T5 Torx Screwdriver
Exibir mais…
  1. Vizio SmartCast Tablet Remote XR6M Micro-USB Port Replacement, Micro-USB Port: passo 1, imagem 1 %32
  2. Vizio SmartCast Tablet Remote XR6M Micro-USB Port Replacement: passo 2, imagem 1 %32 Vizio SmartCast Tablet Remote XR6M Micro-USB Port Replacement: passo 2, imagem 2 %32
    • Insert the tip of the nylon spudger under the black flap, and pull upwards toward yourself to disconnect it.
    • Be careful, as the flap can easily break off.
  3. Vizio SmartCast Tablet Remote XR6M Micro-USB Port Replacement: passo 3, imagem 1 %32 Vizio SmartCast Tablet Remote XR6M Micro-USB Port Replacement: passo 3, imagem 2 %32 Vizio SmartCast Tablet Remote XR6M Micro-USB Port Replacement: passo 3, imagem 3 %32
    • Using the T-5 bit, unscrew the three 5mm screws, two attached to the green board, one attached to the black board.
  4. Vizio SmartCast Tablet Remote XR6M Micro-USB Port Replacement: passo 4, imagem 1 %32 Vizio SmartCast Tablet Remote XR6M Micro-USB Port Replacement: passo 4, imagem 2 %32 Vizio SmartCast Tablet Remote XR6M Micro-USB Port Replacement: passo 4, imagem 3 %32
    • Using the nylon spudger, remove the silver cylindrical component followed by the green then black components
    • Be careful not to break the wires that are holding the three components together.
Conclusão
tate campbell
Membro desde: 09/17/18
439 Reputação
Autoria de 3 guias
Equipe
1Comentário do guia
Is there a way to purchase a replacement battery?
Gasman - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 11
Ao todo: 409
