Violin Strings Replacement
Introdução
Ir para o passo 1This guide is intended to help users through the process of fixing broken or worn out violin strings. A violin has four strings: E, A, D, & G. The order of the strings from left to right is G, D, A, & E. The G string is the deepest pitched string and the E is the highest pitched string. The purpose of this guide is to enable violin players to restring their violin on their own instead of having it done at a music store.
Turn the peg belonging to the string you are wanting to change to loosen the string.
5 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all1Comentário do guia
Thanks for this very clear set of instructions with clear images. I am an amateur violinist and broke a string while tuning. Even I could use these instructions and it was as easy as the post says. Thanks for posting and to ifixit in general.
