Ir para o conteúdo principal
Velocity NoteMagix M10 A82 Keyboard Replacement
Sam Middleton
Sam Middleton e 6 outros colaboradores
Última atualização em August 24, 2016
5 - 15 minutos
Fácil
Guia em destaque
In this guide you will remove a total of three pieces to replace the keyboard. It will be a combination of prying and pulling to complete the task. During this process, it would be a good idea to have some electrical cleaner handy to clean the connections and the plastic pieces of all unwanted residue. This is an easy replacement and can be done within an hour. The only tools needed will be a spudger.
O que você precisa
Peças
Ferramentas
  • Spudger
    Spudger
  1. Velocity NoteMagix M10 A82 Keyboard Replacement, Battery: passo 1, imagem 1 %32 Velocity NoteMagix M10 A82 Keyboard Replacement, Battery: passo 1, imagem 2 %32
    • Place the notebook on the table, with the battery facing away from you.
    • Slide the switch from "lock" to "unlock" with your right hand on the right side of the computer.
    • Maintain holding the right switch in the "unlock" position.
    • Use your left hand to slide the left switch from "lock" to "unlock".
  2. Velocity NoteMagix M10 A82 Keyboard Replacement: passo 2, imagem 1 %32 Velocity NoteMagix M10 A82 Keyboard Replacement: passo 2, imagem 2 %32
    • Maintain both left and right switches in the "unlock" position.
    • Use your forefingers to push the battery out of the computer.
  3. Velocity NoteMagix M10 A82 Keyboard Replacement, Keyboard: passo 3, imagem 1 %32
    • Place the laptop fully opened with the keyboard facing upwards.
    • Remove the hinge cover by wedging the spudger underneath at the bottom edge and gently prying upwards while sliding the spudger along the cover.
  4. Velocity NoteMagix M10 A82 Keyboard Replacement: passo 4, imagem 1 %32
    • Carefully remove the keyboard by lifting the top of the keyboard closest to the screen.
    • Pull the keyboard away from the mousepad.
    • Be careful to not damage the ribbon underneath the keyboard that connects the keyboard to the computer during removal.
  5. Velocity NoteMagix M10 A82 Keyboard Replacement: passo 5, imagem 1 %32
    • Wedge the spudger between the plastic clamp that holds the ribbon in place and carefully pry the connector off.
Conclusão
Sam Middleton
Membro desde: 10/01/13
401 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 14-9, Forte Fall 2013 Membro de Cal Poly, Team 14-9, Forte Fall 2013
CPSU-FORTE-F13S14G9
Membros da 5
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 554
