Velbon CX690 Tripod Mounting Plate Cap Replacement
Introdução
Ir para o passo 1This short but in-depth guide will walk you through the process of replacing a displaced mounting plate cap on the Velbon CX690 Tripod. You will need a welding solution, such as JB Weld, in order to complete this project.
O que você precisa
Ferramentas
Grab the quick-release plate with one hand and the tripod body with the other. Then, pull the quick-release plate straight off of the tripod body.
