Ir para o conteúdo principal
Toshiba Tecra M2 CPU Replacement
Cindy Nguyen
Cindy Nguyen e 5 outros colaboradores
Última atualização em May 7, 2024
45 minutos - 1 hora
Moderada
Despedaçar
Melhor Introdução
O que você precisa
Ferramentas
Exibir mais…
  1. Toshiba Tecra M2 CPU Replacement, Battery: passo 1, imagem 1 %32
    • Flip the laptop upside down so the back compartment is facing up.
    • Place left thumb on the battery lock tab.
    • Place right thumb on the battery release latch.
  2. Toshiba Tecra M2 CPU Replacement: passo 2, imagem 1 %32 Toshiba Tecra M2 CPU Replacement: passo 2, imagem 2 %32
    • Slide both tabs outward at the same time to release battery pack.
  3. Toshiba Tecra M2 CPU Replacement: passo 3, imagem 1 %32
    • Pull out the battery after it has popped out and set aside.
    • The battery and the battery cover are in one piece
  4. Toshiba Tecra M2 CPU Replacement, CPU: passo 4, imagem 1 %32
    • Use a #00 phillips head screwdriver to remove the 8mm screw for the keyboard strip located under the battery.
  5. Toshiba Tecra M2 CPU Replacement: passo 5, imagem 1 %32
    • Turn the device over and open it up to the display.
    • Gently lift a corner of the keyboard strip until it pops out of its position.
  6. Toshiba Tecra M2 CPU Replacement: passo 6, imagem 1 %32
    • Using a #00 phillips head screwdriver, remove the two 4mm screws found underneath the keyboard strip.
  7. Toshiba Tecra M2 CPU Replacement: passo 7, imagem 1 %32 Toshiba Tecra M2 CPU Replacement: passo 7, imagem 2 %32
    • Pop the keyboard up gently and rest on top of the touch pad
    • The keyboard is attached underneath by a thin film. Do not rip the keyboard off. Gently lay it down without ripping the film.
  8. Toshiba Tecra M2 CPU Replacement: passo 8, imagem 1 %32 Toshiba Tecra M2 CPU Replacement: passo 8, imagem 2 %32
    • Using a #00 phillips head screwdriver, remove the 6mm screw holding the metal plate down.
  9. Toshiba Tecra M2 CPU Replacement: passo 9, imagem 1 %32 Toshiba Tecra M2 CPU Replacement: passo 9, imagem 2 %32
    • Gently remove the keyboard connector film from the motherboard with fingers by lifting upwards.
    • Set aside the keyboard.
  10. Toshiba Tecra M2 CPU Replacement: passo 10, imagem 1 %32
    • Using a #00 phillips head screwdriver, remove the three 13mm screws holding down the touch pad's frame from underneath the keyboard.
  11. Toshiba Tecra M2 CPU Replacement: passo 11, imagem 1 %32 Toshiba Tecra M2 CPU Replacement: passo 11, imagem 2 %32 Toshiba Tecra M2 CPU Replacement: passo 11, imagem 3 %32
    • Flip laptop back upside down.
    • Remove the 5mm lock screw, using a #00 phillips head screwdriver.
    • Slide bay latch toward the battery compartment.
    • Remove CD-RW/DVD-ROM drive.
  12. Toshiba Tecra M2 CPU Replacement: passo 12, imagem 1 %32
    • Remove the 4.5mm screw located under the CD-RW/DVD-ROM drive compartment, using a #00 phillips head screwdriver.
  13. Toshiba Tecra M2 CPU Replacement: passo 13, imagem 1 %32
    • Remove the three 17mm screws found on the backside of the laptop using a #00 phillips head screwdriver.
    • Remove the ten 8mm screws using a #00 phillips head screwdriver.
  14. Toshiba Tecra M2 CPU Replacement: passo 14, imagem 1 %32 Toshiba Tecra M2 CPU Replacement: passo 14, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Flip the laptop back over and unplug the touch pad's power cord from the motherboard gently using a pair of tweezers.
  15. Toshiba Tecra M2 CPU Replacement: passo 15, imagem 1 %32 Toshiba Tecra M2 CPU Replacement: passo 15, imagem 2 %32
    • Lift off the plastic cover and set it aside.
  16. Toshiba Tecra M2 CPU Replacement: passo 16, imagem 1 %32 Toshiba Tecra M2 CPU Replacement: passo 16, imagem 2 %32
    • Using a #00 phillips head screwdriver, unscrew the three 5mm screws holding down the heat sink securing bracket.
    • Lift off the securing bracket and set aside.
  17. Toshiba Tecra M2 CPU Replacement: passo 17, imagem 1 %32
    • Wiggle the heat sink until it lifts off the top of your CPU. There is thermal paste underneath and it may stick.
  18. Toshiba Tecra M2 CPU Replacement: passo 18, imagem 1 %32 Toshiba Tecra M2 CPU Replacement: passo 18, imagem 2 %32 Toshiba Tecra M2 CPU Replacement: passo 18, imagem 3 %32
    • Turn a flathead #3 screwdriver counter-clockwise to unlock the CPU socket.
    • Grab the CPU with your index finger and thumb and pull directly upwards.
    • Apply a new coat of thermal paste before reassembling.
    • How to Apply Thermal Paste
Conclusão
Cindy Nguyen
Membro desde: 09/08/14
386 Reputação
Autoria de 3 guias
Equipe
CSU Fullerton, Team 1-6, Bruce Fall 2014 Membro de CSU Fullerton, Team 1-6, Bruce Fall 2014
CSUF-BRUCE-F14S1G6
Membros da 3
Autoria de 9 guias
Um comentário
"Step 4 - CPU" THAT IS NOT A 8MM SCREW! THERE IS NOW A HOLE IN MY COMPUTER!!
[deleted] - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 10
Duração total: 1,686
