Ir para o conteúdo principal
Toshiba Satellite U925T-S2120 Heat Sink Replacement
Andrew Honderich
Andrew Honderich e 6 outros colaboradores
Última atualização em May 7, 2024
15 - 20 minutos
Fácil
In this guide you will learn how to remove the heat sink of your Toshiba Satellite U925T-S2120. If your heat sink is clogged or broken, you may need to replace it. Before beginning this guide you should have all required tools that are listed.
O que você precisa
Ferramentas
Exibir mais…
  1. Toshiba Satellite U925T-S2120 Heat Sink Replacement, Heat Sink: passo 1, imagem 1 %32 Toshiba Satellite U925T-S2120 Heat Sink Replacement, Heat Sink: passo 1, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use tweezers to remove the nine rubber grip pads on the back panel of the laptop.
  2. Toshiba Satellite U925T-S2120 Heat Sink Replacement: passo 2, imagem 1 %32 Toshiba Satellite U925T-S2120 Heat Sink Replacement: passo 2, imagem 2 %32 Toshiba Satellite U925T-S2120 Heat Sink Replacement: passo 2, imagem 3 %32
    • Unscrew the nine 5.8 mm screws using a PH1 screwdriver.
    • Unscrew the two 6.8 mm screws. Set all screws aside.
  3. Toshiba Satellite U925T-S2120 Heat Sink Replacement: passo 3, imagem 1 %32 Toshiba Satellite U925T-S2120 Heat Sink Replacement: passo 3, imagem 2 %32
    • Remove the back panel by inserting the plastic opening tool into the seam of the laptop and pushing the opening tool downwards.
  4. Toshiba Satellite U925T-S2120 Heat Sink Replacement: passo 4, imagem 1 %32 Toshiba Satellite U925T-S2120 Heat Sink Replacement: passo 4, imagem 2 %32
    • Unscrew the three 3.4 mm screws using a PH1 screwdriver.
  5. Toshiba Satellite U925T-S2120 Heat Sink Replacement: passo 5, imagem 1 %32
    • Gently pinch the heat sink with fingers to lift and remove it.
Conclusão
Uma outra pessoa concluiu este guia.
Andrew Honderich
Membro desde: 03/29/17
364 Reputação
Autoria de 3 guias
Equipe
Baylor, Team S5-G5, Williams Spring 2017 Membro de Baylor, Team S5-G5, Williams Spring 2017
BU-WILLIAMS-S17S5G5
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 12
Duração total: 444
