Ir para o conteúdo principal
Toshiba Satellite U840W Processor Fan Replacement.
Tony Aprile
Tony Aprile e 2 outros colaboradores
Última atualização em June 18, 2019
15 minutos
Moderada
Precisa de melhores imagens
If the processor fan stops working, and the system is overheating, Follow this guide to replace it.
O que você precisa
Ferramentas
  1. Toshiba Satellite U840W Processor Fan Replacement., Toshiba Satellite U840W Disassembly Guide: passo 1, imagem 1 %32 Toshiba Satellite U840W Processor Fan Replacement., Toshiba Satellite U840W Disassembly Guide: passo 1, imagem 2 %32
    • There are ten 5mm screws surrounding the edge of the cover.
    • A rubber cap covers the eleventh 5mm screw (in the center).
    • Remove the screws using a Phillips #00 screwdriver.
  2. Toshiba Satellite U840W Processor Fan Replacement.: passo 2, imagem 1 %32 Toshiba Satellite U840W Processor Fan Replacement.: passo 2, imagem 2 %32 Toshiba Satellite U840W Processor Fan Replacement.: passo 2, imagem 3 %32
    • Pry between the casing and cover using a plastic wedge tool.
    • Use the wedge tool to move along the case & slowly pry it open.
    • The wire for the 12v charging port connects the cover to the casing.
  3. Toshiba Satellite U840W Processor Fan Replacement.: passo 3, imagem 1 %32 Toshiba Satellite U840W Processor Fan Replacement.: passo 3, imagem 2 %32 Toshiba Satellite U840W Processor Fan Replacement.: passo 3, imagem 3 %32
    • Disconnect this connector from the motherboard to avoid damaging the motherboard or charging port cable.
  4. Toshiba Satellite U840W Processor Fan Replacement.: passo 4, imagem 1 %32
    • Disconnect the battery.
    • Hold down the power button for ~10 seconds to discharge any stored electricity from the motherboard.
  5. Toshiba Satellite U840W Processor Fan Replacement., Processor Fan: passo 6, imagem 1 %32 Toshiba Satellite U840W Processor Fan Replacement., Processor Fan: passo 6, imagem 2 %32
    • Remove the three 3mm screws using a Phillips #00 screwdriver.
  6. Toshiba Satellite U840W Processor Fan Replacement.: passo 7, imagem 1 %32 Toshiba Satellite U840W Processor Fan Replacement.: passo 7, imagem 2 %32
    • A plastic prying tool can be used to help you remove the fan.
    • Plastic wire guides hold the wire in place. Manipulate the wire out from these guides.
  7. Toshiba Satellite U840W Processor Fan Replacement.: passo 8, imagem 1 %32 Toshiba Satellite U840W Processor Fan Replacement.: passo 8, imagem 2 %32
    • Remove the connector from the motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
Tony Aprile
Membro desde: 02/04/19
118 Reputação
Autoria de 1 guia
Equipe
Gateway, Team S1-G1, Saknee Spring 2019 Membro de Gateway, Team S1-G1, Saknee Spring 2019
GCC-SAKNEE-S19S1G1
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 5
Duração total: 352
