Toshiba Satellite S55t-C5225 RAM Replacement
Introdução
Vá para o passo 1If your Toshiba Satellite S55t-C5225 shuts down abruptly, performance is low, or fails to install new programs then the RAM most likely needs to be replaced. The following guide will walk the user through replacing the RAM in your Toshiba Satellite S55t-C5225.
O que você precisa
Ferramentas
Press on the metals clips on the outside of the RAM to release it.
Gently pull out the first RAM stick. Repeat the process for the other RAM stick.
3 outras pessoas executaram este guia.
