Toshiba Satellite S55t-C5225 Optical Disk Drive Replacement
Introdução
Vá para o passo 1If your Toshiba S55t-C5225 can no longer read CD’s/DVD’s or will not open then your optical disk drive is most likely not operational and needs to be replaced. The following steps are a guide to help the user in replacing the optical disk drive.
O que você precisa
Ferramentas
Carefully slide the optical disk drive to the right to remove from the motherboard.
Uma outra pessoa concluiu este guia.
