Toshiba Satellite S55t-A5389 Processor Replacement
Introdução
Ir para o passo 1If your laptop no longer runs as well as it did, and has become slow, unresponsive, or does not power on. You're processor may be at fault and replacing it could be an option. However before this is done, be sure to check your laptop for any viruses, or any other issues that it may have.
Rotate the lock 90 degrees using a Torx T8 in order to remove the processor.
3 outras pessoas executaram este guia.
