Ir para o conteúdo principal
Toshiba Satellite Radius P55W-B5220 RAM Replacement
Devin Boski
Devin Boski e um outro colaborador
Última atualização em January 11, 2018
5 minutos
Fácil
RAM (Random Access Memory) is hardware that temporarily stores data that allows the computer to access data faster. This guide will instruct you on how to replace your RAM.
O que você precisa
Ferramentas
  1. Toshiba Satellite Radius P55W-B5220 RAM Replacement, Back Cover: passo 1, imagem 1 %32
    • Turn off the laptop before starting.
    • Remove the two rubber feet closest to the hinge with a plastic opening tool.
  2. Toshiba Satellite Radius P55W-B5220 RAM Replacement: passo 2, imagem 1 %32
    • Remove the twelve M2x4mm PH0 Philips head screws.
  3. Toshiba Satellite Radius P55W-B5220 RAM Replacement: passo 3, imagem 1 %32
    • Loosen the back cover with a plastic opening tool.
    • The least damaging way to pry the cover is to start from a corner and run the spudger along the edge.
    • Do not crack or bend the cover.
  4. Toshiba Satellite Radius P55W-B5220 RAM Replacement: passo 4, imagem 1 %32
    • Carefully lift open the cover.
    • Remove the attached purple ribbon cable underneath the cover.
    • Do not rip the ribbon cable.
  5. Toshiba Satellite Radius P55W-B5220 RAM Replacement, RAM: passo 5, imagem 1 %32 Toshiba Satellite Radius P55W-B5220 RAM Replacement, RAM: passo 5, imagem 2 %32
    • Push outward on the clamps holding the RAM in place.
  6. Toshiba Satellite Radius P55W-B5220 RAM Replacement: passo 6, imagem 1 %32
    • Remove the RAM chips.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 679
