Ir para o conteúdo principal
Toshiba Satellite P855-S5102 Hard Drive Replacement
Benson Smith
Benson Smith e um outro colaborador
Última atualização em June 26, 2018
Nenhuma estimativa
Moderada
The laptop's Hard Drive is where data is permanently stored and retrieved on the computer. A good Hard Drive keeps the computer running smoothly. Below are a few steps on how to effectively remove the Hard Drive.
O que você precisa
Ferramentas
  1. Toshiba Satellite P855-S5102 Hard Drive Replacement, Battery: passo 1, imagem 1 %32 Toshiba Satellite P855-S5102 Hard Drive Replacement, Battery: passo 1, imagem 2 %32
    • Push the locking tabs away from each other.
  2. Toshiba Satellite P855-S5102 Hard Drive Replacement: passo 2, imagem 1 %32 Toshiba Satellite P855-S5102 Hard Drive Replacement: passo 2, imagem 2 %32
    • Pull up on the battery to remove.
  3. Toshiba Satellite P855-S5102 Hard Drive Replacement, RAM: passo 3, imagem 1 %32 Toshiba Satellite P855-S5102 Hard Drive Replacement, RAM: passo 3, imagem 2 %32
    • Remove the 3mm Phillips #0 screw from the cover.
  4. Toshiba Satellite P855-S5102 Hard Drive Replacement: passo 4, imagem 1 %32 Toshiba Satellite P855-S5102 Hard Drive Replacement: passo 4, imagem 2 %32 Toshiba Satellite P855-S5102 Hard Drive Replacement: passo 4, imagem 3 %32
    • Use a plastic opening tool to lift up the cover and remove by hand.
  5. Toshiba Satellite P855-S5102 Hard Drive Replacement: passo 5, imagem 1 %32 Toshiba Satellite P855-S5102 Hard Drive Replacement: passo 5, imagem 2 %32 Toshiba Satellite P855-S5102 Hard Drive Replacement: passo 5, imagem 3 %32
    • Two clips secure the RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
    • When released, the RAM module will pop up at a slight angle.
Lift the RAM module to an angle of about 30 degrees and slide it out.
  6. Toshiba Satellite P855-S5102 Hard Drive Replacement, Hard Drive: passo 6, imagem 1 %32
    • Remove the three 3mm Phillips #0 screws from the hard drive.
    • Remove the hard drive.
Conclusão
Benson Smith
Membro desde: 01/25/18
351 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team S20-G3, Passmore Spring 2018 Membro de USF Tampa, Team S20-G3, Passmore Spring 2018
USFT-PASSMORE-S18S20G3
Membros da 4
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 4
Últimos 30 dias: 6
Duração total: 787
