Toshiba Satellite P55W-C5316 RAM Replacement
Introdução
Ir para o passo 1This guide will show you how to replace the RAM on your laptop. There are two RAM slots in this laptop that can be swapped out for other RAM chips.
O que você precisa
Ferramentas
Unscrew the .3mm Phillips head screws on the back panel using the PH1 screwdriver.
The battery is located in the bottom right corner of the laptop.
Remove the four .5mm Phillips head screws on the battery using the PH1 screwdriver.
Lift up the flap to expose the RAM chip.
Un-clip the RAM by pulling the metal clips away from the chip on both sides.
Lift the RAM up from the laptop and pull it away from the connector.
