Ir para o conteúdo principal
Toshiba Satellite P55-A5312 Fan Replacement
Aniketh Bhat
Aniketh Bhat e 4 outros colaboradores
Última atualização em July 31, 2019
Nenhuma estimativa
Moderada
Replacing a damaged or broken fan can help increase the lifespan of your laptop as well as improve performance and limit overheating. First we will remove the back of the laptop. After, we will carefully unscrew and replace the damaged or broken fan.
O que você precisa
Ferramentas
  1. Toshiba Satellite P55-A5312 Fan Replacement, Fan: passo 1, imagem 1 %32 Toshiba Satellite P55-A5312 Fan Replacement, Fan: passo 1, imagem 2 %32 Toshiba Satellite P55-A5312 Fan Replacement, Fan: passo 1, imagem 3 %32
  2. Toshiba Satellite P55-A5312 Fan Replacement: passo 2, imagem 1 %32
    • Locate the 2.5x6mm black screw to the bottom of the tri-colored wires that holds down the fan to the motherboard.
    • Unscrew it with a Philips #0 screwdriver.
  3. Toshiba Satellite P55-A5312 Fan Replacement: passo 3, imagem 1 %32
    • Locate the 4 2x3mm screws holding down the orange heatsink.
    • Unscrew them with a Philips #0 screwdriver.
  4. Toshiba Satellite P55-A5312 Fan Replacement: passo 4, imagem 1 %32
    • Remove the white holder of the red, yellow, and black wires from the beige piece by gently pulling on it.
  5. Toshiba Satellite P55-A5312 Fan Replacement: passo 5, imagem 1 %32
    • Carefully remove the fan from its seating with your hands.
    • Replace with your new fan.
Conclusão
Aniketh Bhat
Membro desde: 01/25/17
216 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 9-1, Banghart Winter 2017 Membro de Cal Poly, Team 9-1, Banghart Winter 2017
CPSU-BANGHART-W17S9G1
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 980
