Toshiba Satellite M45 Power Button Replacement
Introdução
Vá para o passo 1This is a very difficult guide by the average user and it is recommended to double check the power source as well as the power cable.
O que você precisa
Turn the computer off and disconnect the power supply from the power supply port in the back of the computer.
Slide the two battery locks to disconnect the battery.
Pull the battery (with casing) horizontally away from the computer to remove it.
Remove the RAM cover panel screws with a #1 Phillips screwdriver.
Then pry the RAM cover panel off with an opening tool.
Push the tabs that secure the RAM outward (away from the RAM) using your fingers. The RAM should then pop up.
Pull the RAM away from the connection to remove. Continue this process until all RAM sticks have been removed from the device.
Remove the Wi-Fi panel screw with a Phillips #1 screwdriver.
Pry the cover panel off with an opening tool.
Disconnect the black and white wires. Then push the tabs outward (away from the Wi-Fi card) using your fingers. The card should then pop up.
Pull the Wi-Fi card out from the device at a slight angle (horizontal with the casing).
