Ir para o conteúdo principal
Toshiba Satellite M35X-S114 Hard Drive Replacement
Christian Mayorga
Christian Mayorga e 3 outros colaboradores
Última atualização em March 21, 2018
3 - 5 minutos
Fácil
Introdução
Ir para o passo 1
The Hard Drive replacement process involves flipping the laptop over and locating a screw on the right-hand side of the laptop. Once this screw is removed, the hard drive can be separated from the laptop.
While hard drives can be purchased from most online retailers, you may need to search for a hard drive that is compatible for the laptop's specific model. This is because most laptops use more compact and specifically designed hard drives to fit their smaller overall size.
O que você precisa
Ferramentas
  1. Toshiba Satellite M35X-S114 Hard Drive Replacement, Unlock the Battery from its Compartment: passo 1, imagem 1 %32 Toshiba Satellite M35X-S114 Hard Drive Replacement, Unlock the Battery from its Compartment: passo 1, imagem 2 %32
    • Locate the battery near the bottom left-hand side of the device.
    • Locate the two switches above the battery's top left corner.
    • Use any finger to move the smaller switch above the battery to the unlock position.
    • A small icon of a padlock will identify the "lock" and "unlock" positions of the switch.
  2. Toshiba Satellite M35X-S114 Hard Drive Replacement, Move the Battery's Release Switch: passo 2, imagem 1 %32 Toshiba Satellite M35X-S114 Hard Drive Replacement, Move the Battery's Release Switch: passo 2, imagem 2 %32
    • Use any finger to move the larger switch above the battery to the left and hold the switch.
  3. Toshiba Satellite M35X-S114 Hard Drive Replacement, Remove the Battery: passo 3, imagem 1 %32 Toshiba Satellite M35X-S114 Hard Drive Replacement, Remove the Battery: passo 3, imagem 2 %32
    • Place your fingernail or fingertip into the groove near the top right of the battery.
    • Pull the battery out with your finger. Release the larger switch once the battery is out.
  4. Toshiba Satellite M35X-S114 Hard Drive Replacement, Remove the Hard Drive screw: passo 4, imagem 1 %32 Toshiba Satellite M35X-S114 Hard Drive Replacement, Remove the Hard Drive screw: passo 4, imagem 2 %32 Toshiba Satellite M35X-S114 Hard Drive Replacement, Remove the Hard Drive screw: passo 4, imagem 3 %32
    • Locate the Hard Drive.
    • Locate the screw near the Hard Drive.
    • Use a Phillips 00 screwdriver to remove the 7.50mm screw.
  5. Toshiba Satellite M35X-S114 Hard Drive Replacement, Slide the Hard Drive out: passo 5, imagem 1 %32 Toshiba Satellite M35X-S114 Hard Drive Replacement, Slide the Hard Drive out: passo 5, imagem 2 %32
    • Please note that the hard drive from the laptop used is missing.
    • Slide the hard drive out.
    • The hard drive may not slide out easily, and may require a little bit of force in order to be disconnected from the laptop.
Conclusão
Uma outra pessoa concluiu este guia.
Christian Mayorga
Membro desde: 09/09/14
219 Reputação
Autoria de 2 guias
Equipe
CSU Fullerton, Team 2-4, Bruce Fall 2014 Membro de CSU Fullerton, Team 2-4, Bruce Fall 2014
CSUF-BRUCE-F14S2G4
4 Membros
Autoria de 3 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Ao todo: 1,822
