Ir para o conteúdo principal
Toshiba Satellite L675D-S7016 Keyboard Replacement
Austin Bons
Austin Bons e 6 outros colaboradores
Última atualização em May 21, 2024
20 minutos
Moderado
Introdução
Ir para o passo 1
If your keyboard is unresponsive, or you are having some other issues with the hardware on the keyboard, this guide will show you how to safely remove if from the laptop. If you are unsure if the issue with your keyboard is a hardware issue, check out the troubleshooting page to find out.
O que você precisa
Ferramentas
  1. Toshiba Satellite L675D-S7016 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Power down the computer and unplug the power adapter.
  2. Toshiba Satellite L675D-S7016 Keyboard Replacement: passo 2, imagem 1 %32
    • Flip the laptop upside down. Locate the two latches on both sides of the battery.
  3. Toshiba Satellite L675D-S7016 Keyboard Replacement: passo 3, imagem 1 %32 Toshiba Satellite L675D-S7016 Keyboard Replacement: passo 3, imagem 2 %32 Toshiba Satellite L675D-S7016 Keyboard Replacement: passo 3, imagem 3 %32
    • Slide the latch on the right outwards, releasing the lock. The latch stays unlocked once moved.
    • Simultaneously slide the latch on the left outwards while pulling the battery towards you.
    • Do not touch the metal connectors on the laptop and the battery.
  4. Toshiba Satellite L675D-S7016 Keyboard Replacement, Keyboard: passo 4, imagem 1 %32 Toshiba Satellite L675D-S7016 Keyboard Replacement, Keyboard: passo 4, imagem 2 %32 Toshiba Satellite L675D-S7016 Keyboard Replacement, Keyboard: passo 4, imagem 3 %32
    Ferramenta utilizada neste passo:
    Heavy-Duty Spudger
    • Pry under the plastic strip, starting on the top right side of the key board with a Heavy Duty Spudger.
    • Once the first corner is raised, use your hand pulling upwards and release the rest of the strip.
  5. Toshiba Satellite L675D-S7016 Keyboard Replacement: passo 5, imagem 1 %32 Toshiba Satellite L675D-S7016 Keyboard Replacement: passo 5, imagem 2 %32
    • Remove the first 3mm screw with the Phillips #1 screwdriver.
    • Remove the next three 3mm screws.
  6. Toshiba Satellite L675D-S7016 Keyboard Replacement: passo 6, imagem 1 %32 Toshiba Satellite L675D-S7016 Keyboard Replacement: passo 6, imagem 2 %32
    • Lift the keyboard gently . Slide it forward towards the screen and speakers. This reveals the connection needed for the next step.
  7. Toshiba Satellite L675D-S7016 Keyboard Replacement: passo 7, imagem 1 %32 Toshiba Satellite L675D-S7016 Keyboard Replacement: passo 7, imagem 2 %32 Toshiba Satellite L675D-S7016 Keyboard Replacement: passo 7, imagem 3 %32
    • Use the pointed end of the Heavy-Duty Spudger and push the pins toward the screen, leaving them in this position.
    • Carefully slide the connector out of the port.
Conclusão
Uma outra pessoa concluiu este guia.
Austin Bons
Membro desde: 09/22/16
1.131 Reputação
Autoria de 8 guias
Equipe
UC Davis, Team 2-2, Oliver Fall 2016 Membro de UC Davis, Team 2-2, Oliver Fall 2016
UCD-OLIVER-F16S2G2
5 Membros
Autoria de 10 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 22
Últimos 30 dias: 22
Ao todo: 840
