Ir para o conteúdo principal
Toshiba Satellite L675D-S7016 Hard Drive Replacement
Austin Bons
Austin Bons e 5 outros colaboradores
Última atualização em December 18, 2016
6 minutos
Fácil
Introdução
Ir para o passo 1
After going through the Troubleshooting guide, and you hear that your laptop is "clicky" or that the hard drive is not connect, this guide will guide you through the removal of the hard drive.
O que você precisa
Ferramentas
  1. Toshiba Satellite L675D-S7016 Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Power down the computer and unplug the power adapter.
  2. Toshiba Satellite L675D-S7016 Hard Drive Replacement: passo 2, imagem 1 %32
    • Flip the laptop upside down. Locate the two latches on both sides of the battery.
  3. Toshiba Satellite L675D-S7016 Hard Drive Replacement: passo 3, imagem 1 %32 Toshiba Satellite L675D-S7016 Hard Drive Replacement: passo 3, imagem 2 %32 Toshiba Satellite L675D-S7016 Hard Drive Replacement: passo 3, imagem 3 %32
    • Slide the latch on the right outwards, releasing the lock. The latch stays unlocked once moved.
    • Simultaneously slide the latch on the left outwards while pulling the battery towards you.
    • Do not touch the metal connectors on the laptop and the battery.
  4. Toshiba Satellite L675D-S7016 Hard Drive Replacement, Back Panel Removal: passo 4, imagem 1 %32
    • Remove the single captive screw on the back panel with your Phillips #1 screwdriver.
  5. Toshiba Satellite L675D-S7016 Hard Drive Replacement: passo 5, imagem 1 %32 Toshiba Satellite L675D-S7016 Hard Drive Replacement: passo 5, imagem 2 %32
    • Pry the removal tab up. You will feel and hear the first clip release, popping up slightly.
    • Work your way around the border of the panel, releasing the rest of the clips.
    • Once all clips are released, lift the cover up and pull towards you.
  6. Toshiba Satellite L675D-S7016 Hard Drive Replacement, Hard Drive: passo 6, imagem 1 %32 Toshiba Satellite L675D-S7016 Hard Drive Replacement, Hard Drive: passo 6, imagem 2 %32
    • Slide the hard drive to the left, using the silver tab.
    • Pull up the silver tab, removing the hard drive from the slot.
    • Do not touch the metal data pins on the hard drive or computer.
Conclusão
To install a new Hard Drive, follow these instructions in reverse order.
Austin Bons
Membro desde: 09/22/16
1.131 Reputação
Autoria de 8 guias
Equipe
UC Davis, Team 2-2, Oliver Fall 2016 Membro de UC Davis, Team 2-2, Oliver Fall 2016
UCD-OLIVER-F16S2G2
5 Membros
Autoria de 10 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 20
Últimos 30 dias: 28
Ao todo: 1,092
