Toshiba Satellite L55-A Back Cover Replacement
Introdução
Vá para o passo 1Follow this guide to remove the back cover of the Toshiba L55 laptop. This requires partially removing the DVD SuperMultiDrive, as a metal tab is trapped underneath it.
O que você precisa
Ferramentas
Exibir mais…
Flip the laptop over so that the back cover is facing up.
Unscrew the captive Phillips screw securing the RAM cover.
Use an opening tool to pry up the ethernet connector cable from its socket near the RAM module.
Disconnect the cable.
Remove the thirteen 6.8 mm long Phillips screws securing the back cover.
