Ir para o conteúdo principal
Toshiba Satellite L455-S5046 The Fan Replacement
Daryl Spurgeon
Daryl Spurgeon e 2 outros colaboradores
Última atualização em April 19, 2017
10 minutos
Moderado
Introdução
Ir para o passo 1
In this guide we will teach you how to replace the fan on your laptop. Be sure to read the Satellite L455-S5046 Troubleshooting Guide to see if a replacement is necessary.
O que você precisa
Ferramentas
  1. Toshiba Satellite L455-S5046 The Fan Replacement, Battery: passo 1, imagem 1 %32 Toshiba Satellite L455-S5046 The Fan Replacement, Battery: passo 1, imagem 2 %32
    • Find the battery on the back of the computer. Slide both tabs outward towards the side of the laptop and the battery will come loose.
    • Insert your finger under the middle tab and lift the battery out.
  2. Toshiba Satellite L455-S5046 The Fan Replacement, Fan: passo 2, imagem 1 %32
    • Start on the back and unscrew the 12 Phillips #0 11-mm screws holding the back cover down.
  3. Toshiba Satellite L455-S5046 The Fan Replacement: passo 3, imagem 1 %32
    • Pop off the hard drive cover, and then unscrew the four 11-mm Phillips #0 screws.
  4. Toshiba Satellite L455-S5046 The Fan Replacement: passo 4, imagem 1 %32 Toshiba Satellite L455-S5046 The Fan Replacement: passo 4, imagem 2 %32
    • Flip the laptop over. Remove the keyboard as instructed in the keyboard replacement guide.
    • Gently remove the connector visible in the upper right hand corner of the laptop by pulling to the right.
    • Remove the cover slowly. There will be two other connectors on the underside that can be removed by pulling gently.
  5. Toshiba Satellite L455-S5046 The Fan Replacement: passo 5, imagem 1 %32 Toshiba Satellite L455-S5046 The Fan Replacement: passo 5, imagem 2 %32
    • Remove the connector between the fan and the laptop by pulling gently to the left.
    • Remove the two indicated 11-mm Phillips #0 screws.
  6. Toshiba Satellite L455-S5046 The Fan Replacement: passo 6, imagem 1 %32
    • Now gently lift the fan and pull out.
Conclusão
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Ao todo: 291
