Toshiba Satellite E105-S1602 Display Replacement
Introdução
Ir para o passo 1This guide is designed to help you quickly and safely replace the display screen when a problem arises. The display assembly includes the LCD, the front glass, and the display enclosure.
O que você precisa
Ferramentas
Flip the computer over and insert the plastic opening tool under the plastic strip at the top of the keyboard.
Pry the top plastic strip from the top of the keyboard.
Peel the strip completely away from the keyboard.
Locate the four silver screws on the front panel.
Using the Phillips #0, unscrew to remove all four 2.95mm silver screws.
Use the plastic opening tool to pry the top panel up from the base of the computer.
Slowly work your way around the computer with the plastic removing tool to make it easier to lift the top panel away from the base.
Disconnect ribbons, and slowly lift the top panel up, away from the base.
Rotate the computer so the screen is facing you and locate the four plastic screw covers; one at each corner of the screen
Using your fingernail, remove each cover in order to expose the screw.
Uma outra pessoa concluiu este guia.
