Ir para o conteúdo principal
Toshiba Satellite C875-S7304 Display Replacement
Nathan Gareri
Nathan Gareri e 3 outros colaboradores
Última atualização em November 20, 2023
20 - 40 minutos
Moderado
Fotos de ação
Introdução
Ir para o passo 1
Use this guide to replace a defective or shattered display in a Toshiba Satellite C875-S7304.
The display is a hardware component that presents visual information to you when using a computer. If you start to notice problems with the screen images or the glass screen has become cracked from an accidental drop, the display will need to be replaced.
Review the troubleshooting page before using this guide. Some issues may be resolved through display settings or a software update.
Take precaution when removing the display by disconnecting the laptop from any external power source and powering off your laptop completely before beginning the display replacement.
O que você precisa
Ferramentas
Exibir mais…
  1. Toshiba Satellite C875-S7304 Display Replacement, Battery: passo 1, imagem 1 %32 Toshiba Satellite C875-S7304 Display Replacement, Battery: passo 1, imagem 2 %32 Toshiba Satellite C875-S7304 Display Replacement, Battery: passo 1, imagem 3 %32
    • Power off and unplug the charger from your device.
    • Carefully flip your device upside down laying it onto a flat surface with the battery facing you.
    • The two eject switches are located on the right and left side of the battery compartment.
  2. Toshiba Satellite C875-S7304 Display Replacement: passo 2, imagem 1 %32 Toshiba Satellite C875-S7304 Display Replacement: passo 2, imagem 2 %32
    • Slide the right switch further towards the right to lock it into place.
  3. Toshiba Satellite C875-S7304 Display Replacement: passo 3, imagem 1 %32
    • Slide the switch to the left. Continue to push the switch because unlike the right switch, it will not lock into place.
  4. Toshiba Satellite C875-S7304 Display Replacement: passo 4, imagem 1 %32
    • Using both hands, continue to push the left switch and grasp onto the center notch located in between the right and left switch.
    • Pull the center notch towards you and you will notice the battery will start to eject.
  5. Toshiba Satellite C875-S7304 Display Replacement: passo 5, imagem 1 %32
    • Lift the battery out carefully using two hands.
  6. Toshiba Satellite C875-S7304 Display Replacement, Display: passo 6, imagem 1 %32 Toshiba Satellite C875-S7304 Display Replacement, Display: passo 6, imagem 2 %32
    • Carefully flip the device back over so that the 'TOSHIBA' logo faces away from you.
    • Open the laptop to show the display.
  7. Toshiba Satellite C875-S7304 Display Replacement: passo 7, imagem 1 %32
    • Use the spudger to remove the screw covers and then remove the screws using the Phillips #1.
  8. Toshiba Satellite C875-S7304 Display Replacement: passo 8, imagem 1 %32 Toshiba Satellite C875-S7304 Display Replacement: passo 8, imagem 2 %32
    • Using the iFixit opening tool, carefully remove the plastic frame from the display.
  9. Toshiba Satellite C875-S7304 Display Replacement: passo 9, imagem 1 %32
    • Remove two screws from each hinge on either side using the Phillips #1 screwdriver.
    • There are two screws on each hinge.
  10. Toshiba Satellite C875-S7304 Display Replacement: passo 10, imagem 1 %32
    • Rotate the laptop so that the side is facing you.
    • Remove the three screws using the Phillips #1 screwdriver on each side of the display.
    • There will be six total screws removed in this step (three on each side face).
  11. Toshiba Satellite C875-S7304 Display Replacement: passo 11, imagem 1 %32
    • Turn the display over to expose the wiring on the other side.
  12. Toshiba Satellite C875-S7304 Display Replacement: passo 12, imagem 1 %32 Toshiba Satellite C875-S7304 Display Replacement: passo 12, imagem 2 %32
    • Gently loosen the sliding bracket and remove the cable.
    • If you want to use the same webcam, disconnect it from the back of the display.
  13. Toshiba Satellite C875-S7304 Display Replacement: passo 13, imagem 1 %32
    • With the display now fully disconnected, carefully remove it from the device.
Conclusão
3 outras pessoas executaram este guia.
Um comentário
I love this site....best
Hafiz - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 49
Ao todo: 1,154
